map_suite_services_edition_printing_samples
map_suite_services_edition_printing_samples [2015/09/25 04:08]
admin [Print Preview]
-====== ​ Map Suite Services Edition Printing Samples ​ ======
-<div sampleitem>​
-==== Print Preview ====
-<div screenshot>​
-{{servicesedition:​codesamples:​Map Suite Services Edition Sample Print Preview.jpg?​300x180|screenshot}}
-<div content>
-{{:​File:​ServicesEditionSample_PrintPreview_CS_WPF_111115.zip|C#​ WPF Download}}{{:​File:​ServicesEditionSample_PrintPreview_CS_WinForms_111115.zip|C#​ WinForms Download}}
-<div sample_otherlinks>​
-[[Map Suite Samples Applies To|Applies To: Desktop \ Wpf \ Web \ Silverlight \ Services]]
-In this sample we show you how to add robust printing support to your Map Suite applications for the desktop, WPF, web or services environments. ​ Using the code in this sample, you'll be able to build a Print Preview interface that lets your users interactively arrange items (such as a map, scale line, labels, data grid or image) on a virtual page before printing the result to a printer, exporting to a PDF or to a bitmap image. Maps are printed using vector graphics so you can be sure the output will look great on anything from a PDF to a large plotter. ​ The printing system also includes low-level report building classes that make it easy to generate reports in the web or services environment. ​ \\  \\ To help you understand the sample, as well as Map Suite'​s new printing system upon which it is based, check out our [[http://​download.thinkgeo.com/​Videos/​Wiki/​MapSuitePrintingSystemIntroduction.wmv|instructional video]] that will introduce you to all of these concepts and walk you through the sample solution. ​ \\  \\ Please note that you will need version 5.0.102.0 or newer of Map Suite in order to use the new printing features. For more information on how to upgrade, see the [[Map Suite Daily Builds Guide]]. ​ \\  \\ **Note:** Users of Map Suite Web, Silverlight and Services Editions will not have access to the interactive drag-and-drop page layout interface pictured here.  However, these editions can still be used to programmatically design page layouts in code and then export them to a printer.
map_suite_services_edition_printing_samples.1443154134.txt.gz ยท Last modified: 2015/09/25 04:08 by admin
