map_suite_services_edition_faq_labeling [2015/08/20 03:08] 127.0.0.1 external edit |
| - | ====== Map_Suite_Services_Edition_FAQ_Labeling ====== | ||
| - | <noinclude> | ||
| - | {{article rating}} | ||
| - | </noinclude> | ||
| - | ====How can I display decimal degrees as degrees, minutes and seconds?==== | ||
| - | [[Map_Suite_Services_Edition_Labeling_Samples#Decimal Degrees Formatting|Sample:Decimal Degrees Formatting]] | ||
| - | The purpose of this project is to complete the static class DecimalDegreesHelper. This class offers functions to go to and from Decimal Degrees but it lacks the functions handling various formats such as Degrees Decimal Minutes and Degrees Minutes Decimal Seconds. Those formats can be output by different GPS devices and it is handy to know how to manipulate them and convert them to Decimal Degrees, the only format that can be input into a GIS or Mapping application. | ||
| - | ====How do I control how labels are displayed based on fields in the data?==== | ||
| - | [[Map_Suite_Services_Edition_Labeling_Samples#Labeling Based On Columns|Sample:Labeling Based On Columns]] | ||
| - | As a developer developing a mapping application, you may encounter point based shapefile for labeling. All the characteristics for labeling such as font, size, angle, color can be found in the attribute information of the shapefile itself. This project will show how to create a custom TextStyle that will get the value for those different columns and display each feature accordingly. | ||
| - | ====How do I adjust the size of the labels based on feature column data?==== | ||
| - | [[Map_Suite_Services_Edition_Labeling_Samples#Labeling based on size|Sample:Labeling based on size]] | ||
| - | ====How do I use multiple columns in one label?==== | ||
| - | [[Map_Suite_Services_Edition_Labeling_Samples#Multi_Column_Labeling|Sample:Multi Column Labeling]] | ||
| - | In this project, we show some techniques to label features based on various columns. With the CustomStyles property and CustomColumnFetch event, you will see the flexibility you have to label the way you desire in a few lines of code. In this example, we label volcanoes based on four columns on two lines and using two different font styles. | ||
| - | ====How do I display multi labels for a given feature?==== | ||
| - | [[Map_Suite_Services_Edition_Labeling_Samples#Multiple_Labels|Sample:Multiple Labels]] | ||
| - | This sample shows how you can display multiple labels for a given point or feature. You can do this by setting a single TextStyle or multiple TextStyles. If you use a single TextStyle, you can simply use a pattern like "[[ColumnName1]][ColumnName2]" and when Map Suite displays the text it will combine the values of the columns in your pattern. If you use a different styling method, you will need to manually control the offset of each piece of text to avoid overlapping. | ||
| - | ====How do I display multi line labeling?==== | ||
| - | [[Map_Suite_Services_Edition_Labeling_Samples#MultiLine_Labeling|Sample:MultiLine Labeling]] | ||
| - | For more information you can see the discussion forum post below: | ||
| - | http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6955/afv/topic/Default.aspx | ||
