map_suite_routing_features_bug_fixes_change_log
map_suite_routing_features_bug_fixes_change_log [2015/09/09 08:56]
admin [Version 6.0.0.0]
-====== Map Suite Routing Features & Bug Fixes Change Log ======
-=====Version 9.0.0.0=====
-Release date: 06/24/2015
-Release - No Changes
-=====Version 8.0.0.0=====
-Release date: 06/06/2014
-ThinkGeo.MapSuite.Routing Namespace:
-  *Fixed a bug where routing within one road segment which is one-way type doesn'​t work.
-  *Fixed a bug where the Route property of RoutingResult always returns a new created instance.
-  *Fixed a bug where GenerateServiceArea runs into "Input string not in a correct format"​ exception when using X,Y overload.
-  *Fixed a bug that BuildRoutingData method with routableShapeFile parameter creates another new shapefile.
-=====Version 7.0.0.0=====
-Release date: 06/03/2013
-  *Added method to allow for a route to be returned as a single LineShape
-  *Fixed a bug that SingleLineShape Route is not clipping correctly
-  *Fixed a bug that SingleLineShape Route is not snapping to features correctly
-  *Fixed a bug that Service Area Definition does not work if the start feature is near the border of the routing shape file
-  *Fixed a bug that RoutingResult can't get closest point result
-  *Fixed a bug that the Route returned is much longer than expected
-  *Fixed a bug that a clicked point does not snap to the nearest road and sometimes returns a random road segment
-  *Fixed a bug that where the route result is incorrect if the stop points are on a same road
-  *Fixed some spelling issues in Routing "How Do I" samples
-  *Fixed lots of bugs for Map Suite Routing Explorer
-  *Improved the performance greatly when routing with several stops
-  *Improved the performance of getRoute based on several stop points a lot
-  *Improved the route result to make sure it return an ordered LineShape
-=====Version 6.0.0.0=====
-Release date: 05/​14/​2012 ​
-  *Fixed an issue where the process is hang up when routing with only one stopping point.
-=====Version 5.5.0.49=====
-Release date: 12/​31/​2011 ​
-*Fixed an issue where it returns wrong route for some scenarios.
-=====Version 5.5.0.0=====
-Release date: 11/14/2011
-*Fixed an issue where the Features doesn'​t match RoadSegments in RoutingResult.
-*Added GetRoute overload methods and obsoleted some old APIs.
-=====Version 5.0.0.0=====
-Release date: 5/16/2011
-*Fixed a bug in RoutingEngine.GetRouteViaVisitStops method which would throws exceptions for some cases due to not passing simple shape validations.
-*Added validations to check if the file extension is allowed.
-*Added support for routing results as a single lineshape or as multiple lineshapes.
-*Added GenerateRoutableShapeFile method to create routable shapefiles.
-=====Version 4.5.43.0=====
-Release date: 12/14/2010
-*Upgraded the Routing Index Format to speed up performance.
-*Added override method GetRouteViaStops,​ which allows you to get the route using feature IDs.
-*Added many validations for the public API, such as checking file extension, etc.
-*Fixed an issue with TSP initial route distance.
-*Fixed an issue with the GetRouteDirections sample.
-=====Version 4.0.40.0=====
-Release date: 6/15/2010
-*Updated assembly version to 4.0.0.0; included strong-named and weak-named assemblies. Please see the latest post in the Developer Blog for full details. ​
-=====Version 4.0.0=====
-Release date: 5/1/2010
-*Added Visual Studio 2010 support.
-*Added routing support for the Travelling Salesman Problem with fixed start and end points.
-*Added more sample applications for new scenarios.
-*Fixed issue where an unexpected error would occur when routing on complex road networks.
-*Fixed issue that optimizes the route on the last point for Travelling Salesman.
-*Fixed issue with TSP initial route distance.
-*Several API additions. See the API change log for complete details.
-*Updated the API documentation.
-=====Version 3.1.299=====
-Release date: 11/16/2009
-*Concluded public beta and moved to final release.
-*Added support for the Traveling Salesman Problem.
-*Added a set of Silverlight-based "How Do I?" sample apps.
-*Added a set of Web-based "How Do I?" sample apps including VB.NET and C# source code.
-*Some API revisions, including one breaking change. See the API change log for complete details.
-[[Category:​Map Suite Routing]] [[Category:​Web GIS]] [[Category:​Desktop GIS]] [[Category:​GIS]] [[Category:​.NET]]
map_suite_routing_features_bug_fixes_change_log.1441789015.txt.gz ยท Last modified: 2015/09/09 08:56 by admin
