map_suite_routing_faq_general_questions [2015/08/20 03:08] 127.0.0.1 external edit |
| - | ====== Map_Suite_Routing_FAQ_General_Questions ====== | ||
| - | <noinclude> | ||
| - | {{article rating}} | ||
| - | </noinclude> | ||
| - | ====How is the Map Suite Routing Extension Licensed?==== | ||
| - | The Map Suite Routing Extension is licensed on a per developer and per production server basis. If you are deploying your routing solution inside a desktop application then all deployment is royalty-free and all that is needed is a developer license. However, if your routing solution is utilizing a Web or centralized server, additional production server licenses are required. | ||
| - | ====What type of data can I use with the Map Suite Routing Extension?==== | ||
| - | The Map Suite Routing extension can be used with virtually any type of dataset. By utilizing the flexible feature source support inside of Map Suite, you can easily read ShapeFile data, SQL Server 2008 data and Oracle Spatial data, just to name a few examples. Additionally, with Map Suite's extensible framework, you can even build support for your own proprietary formats. | ||
| - | ====How does the Map Suite Routing Extension integrate in with the other Map Suite products?==== | ||
| - | The Map Suite Routing Extension provides a routing layer class that will allow you to easily add and display routes on your map using any of the Map Suite 3.x editions (Desktop, Web, Silverlight or Services). | ||
| - | ====What types of scenarios is the Map Suite Routing plug-in commonly used for?==== | ||
| - | The Map Suite Routing Extension was built for doing routing within a localized area such as your metro area, county or city. However, with the flexible API that the Map Suite Routing Extension offers, you are free to implement a routing solution that meets your specific needs. | ||
| - | [[Category:Map Suite Routing]] [[Category:Web GIS]] [[Category:Desktop GIS]] [[Category:GIS]] [[Category:.NET]] | ||
