map_suite_mvc_edition_spatial_functions_samples [2015/09/06 07:39] admin |
| - | ====== Map Suite MVC Edition Spatial Functions Samples ====== | ||
| - | ====Clipping On Line Layer==== | ||
| - | {{mvcedition:codesamples:Map Suite Wpf Desktop Edition Sample Clipping On Line Layer.jpg?300x180}} | ||
| - | [[Source_Code_WpfDesktopEditionSample ClippingOnLineLayer CS 110210.zip|View Source]] | | ||
| - | {{:File:WpfDesktopEditionSample ClippingOnLineLayer CS 110210.zip|C# Download}} | | ||
| - | [[Map Suite Samples Alternate Languages|Need it in another language?]] | ||
| - | [[Map Suite Samples Applies To|Applies To: MVC \ Desktop \ Web \ Silverlight \ Service \ Wpf]] | ||
| - | ====Create Inner Ring==== | ||
| - | {{mvcedition:codesamples:Map Suite Web Edition Sample Create InnerRing.jpg?300x180}} | ||
| - | [[Source_Code_DesktopEditionSample_CreateInnerRing_CS_100811.zip|View Source]] | | ||
| - | {{:File:DesktopEditionSample_CreateInnerRing_CS_100811.zip|C# Download}} | | ||
| - | ====Distance Query on Projected Layers==== | ||
| - | {{mvcedition:codesamples:Map Suite Web Edition Sample Distance Query On Projected Layers.png?300x180}} | ||
| - | [[Source_Code_DesktopEditionSample DistanceQueryOnProjectedLayers CS 101228.zip|View Source]] | | ||
| - | {{:File:DesktopEditionSample DistanceQueryOnProjectedLayers CS 101228.zip|C# Download}} | | ||
| - | ====FeatureIdsToExclude==== | ||
| - | {{mvcedition:codesamples:Map Suite Web Edition Sample FeatureIdsToExclude.jpg?300x180}} | ||
| - | [[Source_Code_DesktopEditionSample_FeatureIdsToExclude_CS_100519.zip|View Source]] | | ||
| - | {{:File:DesktopEditionSample_FeatureIdsToExclude_CS_100519.zip|C# Download}} | | ||
| - | ====Get Feature Clicked On(Web)==== | ||
| - | {{mvcedition:codesamples:Map Suite Web Edition Sample Get Feature Clicked On Web.jpg?300x180}} | ||
| - | [[Source_Code_WebEditionSample_GetFeatureClickedOn_CS_100715.zip|View Source]] | | ||
| - | {{:File:WebEditionSample_GetFeatureClickedOn_CS_100715.zip|C# Download}} | | ||
| - | [[Map Suite Samples Applies To|Applies To: MVC \ Web \ Silverlight]] | ||
| - | ====Get Feature Clicked On(Web)2==== | ||
| - | {{mvcedition:codesamples:Map Suite Web Edition Sample Get Feature Clicked On Web2.jpg?300x180}} | ||
| - | [[Source_Code_WebEditionSample_GetFeatureClickedOn2_CS_100726.zip|View Source]] | | ||
| - | {{:File:WebEditionSample_GetFeatureClickedOn2_CS_100726.zip|C# Download}} | | ||
| - | ====Intersect Line==== | ||
| - | {{mvcedition:codesamples:Map Suite Web Edition Sample Intersect Line.jpg?300x180}} | ||
| - | [[Source_Code_DesktopEditionSample_IntersectLine_CS_100728.zip|View Source]] | | ||
| - | {{:File:DesktopEditionSample_IntersectLine_CS_100728.zip|C# Download}} | | ||
| - | ====Polygon Shapes To Multipolygon Shapes==== | ||
| - | {{mvcedition:codesamples:Map_Suite_Wpf_Desktop_Edtion_Sample_Polygon_Shapes_To_Multipolygon_Shapes.jpg?300x180}} | ||
| - | [[Source_Code_WpfDesktopEditionSample_PolygonShapesToMultipolygonShape_CS_101126.zip|View Source]] | | ||
| - | {{:File:WpfDesktopEditionSample_PolygonShapesToMultipolygonShape_CS_101126.zip|C# Download}} | | ||
| - | ====Shortest Line Between Two Features with Split==== | ||
| - | {{mvcedition:codesamples:Map Suite Wpf Desktop Edition Sample Shortest Line Splitting Lines.jpg?300x180}} | ||
| - | [[Source_Code_WpfDesktopEditionSample_FindShortestLineandSplittingLines_CS_140425.zip|View Source]] | | ||
| - | {{:File:WpfDesktopEditionSample_FindShortestLineandSplittingLines_CS_140425.zip|C# Download}} | | ||
| - | This sample will show you how to find the closest line between two features by using the **GetShortestLineTo** API and how to split a line at a given point using the **GetLineOnALine** API. These APIs can be very useful when doing spatial analysis and editing of features. This sample also allows you to dynamically alter the test features using the **EditOverlay** so you can try out different scenarios and see the results quickly. A MapShapes layer is used to display and style the individual results.\\ \\ \\ \\ **Note:** This sample requires that you reference DLLs from the Map Suite WPF Desktop Edition [[Map Suite Daily Builds Guide|daily development build]] version 7.0.318.0 or later. | ||
| - | ====Sweep Angle Desktop==== | ||
| - | {{mvcedition:codesamples:Map Suite Web Edition Sample Sweep Angle Desktop.jpg?300x180}} | ||
| - | [[Source_Code_DesktopEditionSample_SweepAngle_CS_100506.zip|View Source]] | | ||
| - | {{:File:DesktopEditionSample_SweepAngle_CS_100506.zip|C# Download}} | | ||
