map_suite_mvc_edition_labeling_samples [2015/09/18 02:58] admin |
| - | ====== Map Suite MVC Edition Labeling Samples ====== | ||
| - | ==== Draggable Labels ==== | ||
| - | <div screenshot> | ||
| - | {{mvcedition:codesamples:Map Suite Web Edition Sample Draggable Labels.jpg?300x180}} | ||
| - | <div content> | ||
| - | [[Source_Code_WpfDesktopEditionSample_DraggableLabels CS 101013.zip|View Source]] | ||
| - | {{:File:WpfDesktopEditionSample_DraggableLabels_CS_20140617.zip|C# Download}} | ||
| - | [[Map Suite Samples Applies To|Applies To: MVC \ Web \ Wpf]] | ||
| - | ==== Labeling based on size ==== | ||
| - | {{mvcedition:codesamples:Map Suite Web Edition Sample Labeling based on size.jpg?300x180}} | ||
| - | [[Source_Code_DesktopEditionSample_LabelingBasedOnSize_CS_100608.zip|View Source]] | ||
| - | {{:File:DesktopEditionSample_LabelingBasedOnSize_CS_100608.zip|C# Download}} | ||
| - | ==== MultiLine Labeling ==== | ||
| - | [[Source_Code_WpfDesktopEditionSample MultiLineLabeling CS 110316.zip|View Source]] | ||
| - | {{:File:WpfDesktopEditionSample MultiLineLabeling CS 110316.zip|C# Download}} | ||
| - | ==== Multiple Labels ==== | ||
| - | {{desktopedition:codesamples:Map Suite Samples Multiple Labels.png?300x180}} | ||
| - | [[Source_Code_DesktopEditionSample_MultipleLabels_CS_100128.zip|View Source]] | ||
| - | {{:File:DesktopEditionSample_MultipleLabels_CS_100128.zip|C# Download}} | ||
| - | This sample shows how you can display multiple labels for a given point or feature. You can do this by setting a single TextStyle or multiple TextStyles. If you use a single TextStyle, you can simply use a pattern like "[ColumnName1][ColumnName2]..." and when Map Suite displays the text it will combine the values of the columns in your pattern. If you use a different styling method, you will need to manually control the offset of each piece of text to avoid overlapping.\\ \\ For more information you can see the discussion forum post below: \\ http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6955/afv/topic/Default.aspx | ||
| - | {{page>Map Suite Services Edition Labeling Samples}} | ||
