map_suite_mvc_edition_interactiveoverlays_samples [2015/08/28 07:48] admin [Custom Track Polygon] |
| - | ====== Map Suite MVC Edition InteractiveOverlays Samples ====== | ||
| - | ====Custom Track Line==== | ||
| - | {{mvcedition:codesamples:Map Suite Web Edition Sample Custom Track Line.jpg?300x180}} | ||
| - | [[Source_Code_DesktopEditionSample_CustomTrackLine_CS_100210.zip|View Source]] | | ||
| - | [[:File:DesktopEditionSample_CustomTrackLine_CS_100210.zip|C# Download]] | | ||
| - | [[Map Suite Desktop Edition|Desktop]] | | ||
| - | [[Map Suite Samples Applies To|Applies To: MVC Desktop Web Silverlight Services Wpf]] | ||
| - | ====Custom Track Polygon==== | ||
| - | {{mvcedition:codesamples:Map Suite Web Edition Sample Custom Track Polygon.jpg?300x180}} | ||
| - | [[Source_Code_DesktopEditionSample_CustomTrackPolygon_CS_100413.zip|View Source]] | | ||
| - | [[:File:DesktopEditionSample_CustomTrackPolygon_CS_100413.zip|C# Download]] | | ||
| - | ====Dragged Point Style==== | ||
| - | {{webedition:Map Suite Web Edition Sample Dragged Point Style.jpg?300x180}} | ||
| - | [[Source_Code_DesktopEditionSample_DraggedPointStyle_CS_091208.zip|View Source]] |[[:File:DesktopEditionSample_DraggedPointStyle_CS_091208.zip|C# Download]] | | ||
| - | [[Map Suite Samples Applies To|Applies To: MVC Desktop Web Silverlight Services Wpf ]] | ||
| - | ====Dynamic Info On TrackShapes==== | ||
| - | {{webedition:Map Suite Web Edition Sample Dynamic Info On TrackShapes.JPG?300x180}} | ||
| - | [[Source_Code_DesktopEditionSample_DynamicInfoOnTrackShapes_CS_090805.zip|View Source]] | | ||
| - | [[:File:DesktopEditionSample_DynamicInfoOnTrackShapes_CS_090805.zip|C# Download]] | | ||
| - | [[Map Suite Samples Applies To|Applies To: MVC Desktop Web Silverlight Wpf]] | ||
| - | This project is for the Desktop version and it shows how to handle TrackOverlay to obtain dynamic information about the shape being tracked. \\ | ||
| - | In this example, you will see displayed in a groupbox, properties such as perimeter and area as the shape is being tracked. | ||
| - | In this project, you will learn how to handle events such as TrackStarted, MouseMoved and TrackEnded of TrackOverlay for that purpose. | ||
| - | Getting dynamic info of a shape being tracked can be handy in situation where before committing to get the completed shape, you want to know more about the shape. For example, if you are tracking a search zone, you get dynamically info about its area. | ||
| - | This project will be followed by other related projects. One will show how to create one’s own inherited TrackOverlay for having the possibility to abort tracking by pressing a key. Another project will show how to display dynamic info inside the shape itself instead of using a separate control. | ||
| - | ====EditOverlay Styles==== | ||
| - | {{webedition:Map Suite Web Edition Sample EditOverlay Styles.jpg?300x180}} | ||
| - | [[Source_Code_WebEditionSample_EditOverlayStyles_CS_100910.zip|View Source]] | | ||
| - | [[:File:WebEditionSample_EditOverlayStyles_CS_100910.zip|C# Download]] | | ||
| - | [[Map Suite Web Edition|Web]] | | ||
| - | ====Select with Track Shape==== | ||
| - | {{webedition:Map Suite Web Edition Sample Select With TrackShape.jpg?300x180}} | ||
| - | [[Source_Code_DesktopEditionSample_SelectWithTrackShape_CS_100315.zip|View Source]] |[[:File:DesktopEditionSample_SelectWithTrackShape_CS_100315.zip|C# Download]] | | ||
| - | [[Map Suite Samples Applies To|Applies To: MVC\Desktop\Web\Silverlight\Wpf]] | ||
| - | In today’s Desktop project, we combine the skills we learned in the samples “Spatial Query A Feature Layer” and “Track And Edit Shapes”. You can see how we use the event TrackEnded to get the RectangleShape from the tracked shape of TrackOverlay to do the spatial query. In this example, we use a Rectangle but you could also very easily use another shape such as Polygon, Circle, etc. | | ||
| - | ====Tracked Shapes to WKT==== | ||
| - | {{webedition:Map Suite Web Edition Sample Tracked Shapes to WKT.jpg?300x180}} | ||
| - | [[Source_Code_DesktopEditionSample_TrackedShapesToWKT_CS_100513.zip|View Source]] | | ||
| - | [[:File:DesktopEditionSample_TrackedShapesToWKT_CS_100513.zip|C# Download]] | | ||
| - | [[Map Suite Samples Applies To|Applies To: MVC Desktop Web Silverlight Wpf ]] | ||
| - | ====Vertex Tolerance==== | ||
| - | {{webedition:Map Suite Web Edition Sample Vertex Tolerance.jpg?300x180}} | ||
| - | [[Source_Code_DesktopEditionSample_VertexTolerance_CS_091210.zip|View Source]] | | ||
| - | [[:File:DesktopEditionSample_VertexTolerance_CS_091210.zip|C# Download]] | | ||
