map_suite_desktop_edition_spatial_functions_samples [2015/09/16 03:39] admin [Shortest Line Between Two Features with Split] |
| - | ====== Map Suite Desktop Edition Spatial Functions Samples ====== | ||
| - | ==== Clipping On Line Layer ==== | ||
| - | {{desktopedition:codesamples:Map Suite Wpf Desktop Edition Sample Clipping On Line Layer.jpg?300x180}} | ||
| - | [[Source_Code_WpfDesktopEditionSample ClippingOnLineLayer CS 110210.zip|View Source]] | | ||
| - | {{:File:WpfDesktopEditionSample ClippingOnLineLayer CS 110210.zip|C# Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\ | ||
| - | ==== Create Inner Ring ==== | ||
| - | {{desktopedition:codesamples:Map Suite Desktop Edition Sample Create InnerRing.jpg?300x180}} | ||
| - | [[Source_Code_DesktopEditionSample_CreateInnerRing_CS_100811.zip|View Source]] | | ||
| - | {{:File:DesktopEditionSample_CreateInnerRing_CS_100811.zip|C# Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\ | ||
| - | ==== Distance Query on Projected Layers ==== | ||
| - | {{desktopedition:codesamples:Map Suite Desktop Edition Sample Distance Query On Projected Layers.png?300x180}} | ||
| - | [[Source_Code_DesktopEditionSample DistanceQueryOnProjectedLayers CS 101228.zip|View Source]] | | ||
| - | {{:File:DesktopEditionSample DistanceQueryOnProjectedLayers CS 101228.zip|C# Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\ | ||
| - | This sample shows how to use the method GetFeaturesWithDistanceOf when the data is projected. We just input the unit which is projected to, do not need to mind what the real unit is for the internal data before projection. It works fine with Map Suite Assemblies 4.5.54.0 or later. | ||
| - | ==== FeatureIdsToExclude ==== | ||
| - | {{desktopedition:codesamples:Map Suite Desktop Edition Sample FeatureIdsToExclude.jpg?300x180}} | ||
| - | [[Source_Code_DesktopEditionSample_FeatureIdsToExclude_CS_100519.zip|View Source]] | | ||
| - | {{:File:DesktopEditionSample_FeatureIdsToExclude_CS_100519.zip|C# Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\ | ||
| - | ==== Get Feature Clicked On(Desktop) ==== | ||
| - | {{desktopedition:codesamples:Map Suite Desktop Edition Sample Get Feature Clicked On Desktop.jpg?300x180}} | ||
| - | [[Source_Code_DesktopEditionSample_GetFeatureClickedOn_CS_100715.zip|View Source]] | | ||
| - | {{:File:DesktopEditionSample_GetFeatureClickedOn_CS_100715.zip|C# Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\ | ||
| - | [[Map Suite Samples Applies To|Applies To: Desktop \ Wpf ]] | ||
| - | The purpose of this project is to show the technique for finding the feature the user clicked on. To give the user the expected behavior, a buffer in screen coordinate needs to be set so that the feature get selected within a constant distance in screen coordinate to where the user clicked on regardless on the zoom level. This project will show how to accomplish that task regardless of the layer type (polygon, line or point based) and the zoom level of the current extent of the map. This is a Desktop project. | ||
| - | ==== Intersect Line ==== | ||
| - | {{desktopedition:codesamples:Map Suite Desktop Edition Sample Intersect Line.jpg?300x180}} | ||
| - | [[Source_Code_DesktopEditionSample_IntersectLine_CS_100728.zip|View Source]] | | ||
| - | {{:File:DesktopEditionSample_IntersectLine_CS_100728.zip|C# Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\ | ||
| - | ==== Polygon Shapes To Multipolygon Shapes ==== | ||
| - | {{desktopedition:codesamples:Map_Suite_Wpf_Desktop_Edtion_Sample_Polygon_Shapes_To_Multipolygon_Shapes.jpg?300x180}} | ||
| - | [[Source_Code_WpfDesktopEditionSample_PolygonShapesToMultipolygonShape_CS_101126.zip|View Source]] | | ||
| - | {{:File:WpfDesktopEditionSample_PolygonShapesToMultipolygonShape_CS_101126.zip|C# Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\ | ||
| - | ==== Shortest Line Between Two Features with Split ==== | ||
| - | {{desktopedition:codesamples:Map Suite Wpf Desktop Edition Sample Shortest Line Splitting Lines.jpg?300x180}} | ||
| - | [[Source_Code_WpfDesktopEditionSample_FindShortestLineandSplittingLines_CS_140425.zip|View Source]] | | ||
| - | {{:File:WpfDesktopEditionSample_FindShortestLineandSplittingLines_CS_140425.zip|C# Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\ | ||
| - | [[Map Suite Samples Applies To|Applies To: Desktop \ Web \ MVC \ Silverlight \ Services \ WPF ]] | ||
| - | This sample will show you how to find the closest line between two features by using the //GetShortestLineTo// API and how to split a line at a given point using the //GetLineOnALine// API. These APIs can be very useful when doing spatial analysis and editing of features. This sample also allows you to dynamically alter the test features using the //EditOverlay// so you can try out different scenarios and see the results quickly. A MapShapes layer is used to display and style the individual results.\\ \\ \\ \\ **Note:** This sample requires that you reference DLLs from the Map Suite WPF Desktop Edition [[Map Suite Daily Builds Guide|daily development build]] version 7.0.318.0 or later. | ||
| - | ==== Sweep Angle Desktop ==== | ||
| - | {{desktopedition:codesamples:Map Suite Desktop Edition Sample Sweep Angle Desktop.jpg?300x180}} | ||
| - | [[Source_Code_DesktopEditionSample_SweepAngle_CS_100506.zip|View Source]] | | ||
| - | {{:File:DesktopEditionSample_SweepAngle_CS_100506.zip|C# Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\ | ||
| - | {{page>Map Suite Services Edition Spatial Functions Samples}} | ||
