map_suite_desktop_edition_miscellaneous_samples
map_suite_desktop_edition_miscellaneous_samples [2015/09/17 13:28]
-====== ​ Map Suite Desktop Edition Miscellaneous Samples ​ ======
-<div sampleitem>​
-====  Custom Scale Bar  ====
-<div screenshot>​
-{{desktopedition:​codesamples:​Map Suite Desktop Edition Sample Custom Scale Bar.jpg?​300x180}}
-<div content>
-[[Source_Code_WebEditionSample_CustomScaleBar_CS_100810.zip|View Source]]
-{{:​File:​WebEditionSample_CustomScaleBar_CS_100810.zip|C#​ Download}}
-<div sample_otherlinks>​
-In today’s Web project, we learn how to extend ScaleBarAdornmentLayer to create a custom scale bar that is based on a projection of choice instead of the projection of the map. This can be useful when the displayed projection of the map has highly distortable distances especially at high latitudes such as Spherical Mercator (used by Google Map, Virtual Earth, Yahoo maps etc). Using a scale bar based on distance geometry of the Geodetic (WGS84) projection will give a more accurate result. Note that the CustomScaleBar class is based on MapSuiteCore and can be used in any other versions of MapSuite such as Desktop.
-<div sampleitem>​
-====  Draw Custom Exception ​ ====
-<div screenshot>​
-{{desktopedition:​codesamples:​Map Suite Desktop Edition Sample Draw Custom Exception.png?​300x180}}
-<div content>
-[[Source_Code_DesktopEditionSample_DrawCustomException_CS_100127.zip|View Source]]
-{{:​File:​DesktopEditionSample_DrawCustomException_CS_100127.zip|C#​ Download}}
-This sample shows how you can suppress and draw exceptions in desktop overlays instead of throwing them. There is a little-known feature in the Map Suite Desktop Edition Overlay class that allows you to draw an exception in the event an exception is thrown during the drawing process. We have a default image we draw in this case; however, you can override this using the DrawExceptionCore method and draw whatever you want. By default we always throw expections, but to start drawing them you can use the Overlay.DrawExceptionMode property.
-<div sampleitem>​
-====  Managing Cache  ====
-<div screenshot>​
-<div content>
-[[Source_Code_DesktopEditionSample_ManagingCache_CS_100508.zip|View Source]]
-{{:​File:​DesktopEditionSample_ManagingCache_CS_100508.zip|C#​ Download}}
-[[Map Suite Samples Applies To|Applies To: Desktop ]]
-This project is an introduction on how to handle some basic principles of caching the map in the Desktop edition. Cache has the advantage of reusing existing images of the map when revising areas of the map that have already have been drawn. When in Snap Up mode for Zoom level snapping, cache is very handy. But it is a recommendable practice to not use it when the Zoom Level snapping mode is set to none because it can have the unintended consequence of generating an almost unlimited number of tiles. This project will be followed by other ones showing more advanced features of caching.
-<div sampleitem>​
-====  Map Suite Explorer ​ ====
-<div screenshot>​
-{{desktopedition:​codesamples:​Map_Suite_Desktop_Edition_Sample_Map_Suite_Explorer.jpg?​300x180}}
-<div content>
-[[Source_Code_DesktopEditionSample MapSuiteExplorer CS 100923.zip|View Source]]
-{{:​File:​DesktopEditionSample MapSuiteExplorer CS 100923.zip|C#​ Download}}
-This week, we decided to publish in the Code Community the project for Map Suite Explorer. You are already familiar with that free Desktop tool that comes with any edition of Map Suite. It is a basic GIS tool that allows you to view your geographic data and its tabular information. It also allows doing some basic manipulation on your date such as building the spatial index. With the source code at your disposition,​ you can cut time developing your own application by having at your disposal the code for doing common tasks such as loading, unloading layers, building spatial index, changing styles etc. You will also find interesting the legend and see how you can add, remove, move up and down the different layers. It is by far the most comprehensive project in the Code Community to that date. You will need the reference for MapSuiteDesktop.dll and MapSuiteCore.dll (full or evaluation) to run it.
-<div sampleitem>​
-====  MDI Form  ====
-<div screenshot>​
-{{desktopedition:​codesamples:​Map Suite Desktop Edition Sample MDI Form.jpg?​300x180}}
-<div content>
-[[Source_Code_DesktopEditionSample_MDIform_CS_100405.zip|View Source]]
-{{:​File:​DesktopEditionSample_MDIform_CS_100405.zip|C#​ Download}}
-In today’s project, we show how to have the WinformsMap control in a MDI form. Using an MDI form with a map background can represent a challenge. You will see in this project the technique to display properly a child form on top of the map. You can also notice how the map is accessed from the child form by plotting points on it from the child form.
-<div sampleitem>​
-====  Topology Validation ​ ====
-<div screenshot>​
-{{desktopedition:​codesamples:​Map Suite Desktop Edition Sample Topology Validation.jpg?​300x180}}
-<div content>
-[[Source_Code_DesktopEditionSample_TopologyValidation_CS_120904.zip|View Source]]
-{{:​File:​DesktopEditionSample TopologyValidation CS 120904.zip|C#​ Download}}
-<div sampleitem>​
-====  Use Map with MVC Framework ​ ====
-<div screenshot>​
-{{desktopedition:​codesamples:​Map Suite Desktop Edition Sample Use Map with MVC Framework.png?​300x180}}
-<div content>
-[[Source_Code_WebEditionSample_UseMapWithMVCFramework_CS.zip|View Source]]
-{{:​File:​WebEditionSample_UseMapWithMVCFramework_CS_141211.zip|C#​ Download}}
-This project demonstrates how to create a web-based map using Microsoft ASP.NET MVC 1.0 and Map Suite Web Edition. To meet the requirements of MVC, we inherit the interface IMapInitializer in the controller, which has a function InitializeMap that is overridden in the controller. We then implement the class "​MapInitializerHelper"​ to initialize the map instance.
map_suite_desktop_edition_miscellaneous_samples.1442496520.txt.gz · Last modified: 2015/09/17 13:28 by admin
