map_suite_desktop_edition_layers_featuresources_samples
map_suite_desktop_edition_layers_featuresources_samples [2015/09/17 02:31]
admin [Combining Overlays]
-====== Map Suite Desktop Edition Layers & FeatureSources Samples ======
-==== Combining Overlays ====
-<div sampleitem>​
-{{desktopedition:​codesamples:​Map Suite Wpf Desktop Edition S57Viewer.jpg?​300x180}}
-[[Source_Code_WpfDesktopEditionSample_S57Viewer.zip|View Source]] |
-{{:​File:​WpfDesktopEditionSample_S57Viewer_150724.zip|C#​ Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\
-[[Map Suite Samples Applies To|Applies To: Desktop \ Web \ Silverlight \ Wpf ]]
-Today’s project is a tool of ENC Viewer for displaying unencrypted Electronic Navigational Charts (ENCs) available in the S-57 exchange format (*.000). ​
-This tool takes use of Map Suite HydrographyExtension to display ENC data in compliance with the latest version of ECDIS Presentation Library Edition 4.0, which is defined by the International Hydrographic Organization (IHO) in the special publication S-52.
-<div sampleitem>​
-{{desktopedition:​codesamples:​Map Suite Desktop Edition Sample Combining Overlays.jpg?​300x180}}
-[[Source_Code_WpfDesktopEditionSample_CombiningOverlays_101011.zip|View Source]] |
-{{:​File:​WpfDesktopEditionSample_CombiningOverlays_CS_101011.zip|C#​ Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\
-==== Create GRID ====
-<div sampleitem>​
-{{desktopedition:​codesamples:​Map Suite Desktop Edition Sample Create GRID.jpg?​300x180}}
-[[Source_Code_DesktopEditionSample CreateGRID CS 110512.zip|View Source]] |
-{{:​File:​DesktopEditionSample CreateGRID CS 110512.zip|C#​ Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\
-==== Edit Attribute Of Shapefile ====
-<div sampleitem>​
-{{desktopedition:​codesamples:​Map Suite Wpf Desktop Edition Sample Edit Attribute Of Shapefile.jpg?​300x180}}
-[[Source_Code_WpfDesktopEditionSample_EditAttributeOfShapefile_CS_110306.zip|View Source]] |
-{{:​File:​WpfDesktopEditionSample_EditAttributeOfShapefile_CS_110306.zip|C#​ Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\
-==== Edit Geometry Of Shapefile ====
-<div sampleitem>​
-{{desktopedition:​codesamples:​Map Suite Desktop Edition Sample Edit Geometry Of Shapefile.jpg?​300x180}}
-[[Source_Code_DesktopEditionSample_EditGeometryOfShapefile_CS_101021.zip|View Source]] |
-{{:​File:​DesktopEditionSample_EditGeometryOfShapefile_CS_101021.zip|C#​ Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\
-==== Graphic Logo Adornment Layer ====
-<div sampleitem>​
-{{desktopedition:​codesamples:​Map Suite Services Edition Sample Graphic Logo Adornment Layer.png?​300x180}}
-[[Source_Code_DesktopEditionSample_GraphicLogoAdornmentLayer_CS_100128.zip|View Source]] |
-{{:​File:​DesktopEditionSample_GraphicLogoAdornmentLayer_CS_100128.zip|C#​ Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\
-[[Map Suite Samples Applies To|Applies To: Desktop \ Services \ Wpf ]]
-This sample shows how you can display your logo on the map using an AdornmentLayer. The advantage of using an Adornment is that the graphic stays in place and doesn'​t move as you pan your map. The sample should work for various kinds of logos and allow you to change the position using the AdornmentLayer'​s properties.
-<div sampleitem>​
-==== Get Data From Server With WCF ====
-<div sampleitem>​
-{{desktopedition:​codesamples:​RequireDataFromServerUsingWcf.PNG?​300x180}}
-[[Source_Code_SilverlightEditionSample_GetDataFromServerWithWcf_CS.zip|View Source]] |
-{{:​File:​SilverlightEditionSample_GetDataFromServerWithWcf_CS_141211.zip|C#​ Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\
-In this Silverlight-based project, we are going to take a look at how to get geometry data from the server side using the WCF service with Map Suite Silverlight Edition, while keeping all map data on the server side. You can click any of the countries on the map to call a WCF service, which will require data from the server, and then a popup will appear with information about that country.
-==== Heat Map ====
-<div sampleitem>​
-{{desktopedition:​codesamples:​Map Suite Desktop Edition Sample Heat Map.jpg?​300x180}}
-[[Source_Code_DesktopEditionSample_HeatMap_CS_091022.zip|View Source]] |
-{{:​File:​DesktopEditionSample_HeatMap_CS_101210.zip|C#​ Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\
-Heat maps is a technique increasingly used in various fields such in biology and other fields. See http://​en.wikipedia.org/​wiki/​Heat_map. They are also used for displaying areas of webs page most frequently scanned by users. http://​csscreme.com/​heat-maps/​.\\ ​  \\ At ThinkGeo, we are taking this concept to GIS and applying it to geographic maps. Heat maps are a great way to give the users a visually compelling representation of the distribution and intensity of geographic phenomenon. \\  \\ Today, we are posting two Desktop projects on that subject. The first one is using the swine flu data we used in an earlier project. You can see how powerful the visualization of that data is to show the spatial distribution flu swine cases. In the next project, you will see how to take into account column values to produce various degrees of intensity using some earthquake data. In those two projects, you will need references to MapSuiteCore.dll and  DesktopEdition.dll.
-==== Heat Map with earthquakes ====
-<div sampleitem>​
-{{desktopedition:​codesamples:​Map Suite Desktop Edition Sample Heat Map with earthquakes.jpg?​300x180}}
-[[Source_Code_DesktopEditionSample_HeatMapWithEarthquakes_CS_091022.zip|View Source]] |
-{{:​File:​DesktopEditionSample_HeatMapWithEarthquakes_CS_101210.zip|C#​ Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\
-After the project on displaying swine flu data using the heat map technique, here you learn how to apply parameters other than strictly spatial distribution to affect the coloring of the map.\\ ​  \\ In this example, the magnitude of each earthquake (from 0 to 12) is taken into account to influence the displaying of the heat map. The result is California appearing even more intense than if only the spatial distribution were taken into account.\\ ​ \\ As for the previous project, you will need references to MapSuiteCore.dll,​ DesktopEdition.dll. As a caveat on heat map in GIS, it is worth mentioning that while this is great tool for displaying data in a very appealing and communicative way, it cannot be used as an analysis tool for studying spatial behaviors. For spatial analysis, GRID is the appropriate tool. Although a heat map looks like a GRID, it is not one and it cannot substitute GRID for spatial analysis. ​ \\
-==== Highlight at Mouse Hover ====
-<div sampleitem>​
-{{desktopedition:​codesamples:​Map Suite WPF Desktop Edition Sample Highlight At Mouse Hover.jpg?​300x180}}
-[[Source_Code_WpfDesktopEditionSample_HighlightAtMouseHover_CS_120131.zip|View Source]] |
-{{:​File:​WpfDesktopEditionSample_HighlightAtMouseHover_CS_120131.zip|C#​ Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\
-In this WPF project, we show you how to highlight a feature when the user hovers the mouse pointer over it. This effect can be realized in Map Suite by using a timer and doing some spatial querying based on the location of the mouse pointer. This sample works with area-based features but the same could be accomplished with point- or line-based features simply by using different spatial queries.
-==== Image Stream Loading ====
-<div sampleitem>​
-{{desktopedition:​codesamples:​Map Suite Desktop Edition Sample Image Stream Loading.jpg?​300x180}}
-[[Source_Code_DesktopEditionSample_ImageStreamLoading_CS_100701.zip|View Source]] |
-{{:​File:​DesktopEditionSample_ImageStreamLoading_CS_100701.zip|C#​ Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\
-==== KML Extension ====
-<div sampleitem>​
-{{desktopedition:​codesamples:​Map Suite Services Edition Sample KML Extension.jpg?​300x180}}
-[[Source_Code_DesktopEditionSample_KmlExtension_CS_100623.zip|View Source]] |
-{{:​File:​DesktopEditionSample_KmlExtension_CS_100623.zip|C#​ Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\
-KML is the file format for displaying geographic data in a Google Earth browser such as Google Earth. Now, you can also display such a file on a Map Suite control. Thanks to its flexible architecture to extent to new file formats, in today’s project we wrote the logic for supporting KML. Look at the class KmlfeatureSource inheriting from FeatureSource to see how the logic for reading FML files was implemented. As well, you can see the class KmlStyle inheriting from Style for the drawing logic. And feel free to modify and improve those classes with your own implementations.
-==== Latitude Longitude Graticule ====
-<div sampleitem>​
-{{desktopedition:​codesamples:​Map Suite Desktop Edition Sample Latitude Longitude Graticule.jpg?​300x180}}
-[[Source_Code_DesktopEditionSample_LatLongGraticule_CS_090827.zip|View Source]] |
-{{:​File:​DesktopEditionSample_LatLongGraticule_CS_090827.zip|C#​ Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\
-After the projects on North Arrow and Compass, we created another project related to Adornment Layer to have a more stylish map and give more information to the user navigating the map. \\   \\ In this project, we create a Graticule Adorment Layer that shows Meridians and Parallels displaying through the map. Meridians are lines of longitude and they have a North South orientation. Parallels are lines of latitude and they have an East West orientation. ​ \\ Showing graticule for latitude and longitude is a standard way in cartography to give spatial references to the users. \\  \\ You will find two zip files. One is for the Desktop Edition “LatLongGraticule” and it shows nicely the effect of the meridians and parallels as you pan and zoom in and out. You will also see, as additional spatial references to the users, the latitude and longitude location at the mouse pointer in labels at the mouse move event. You will see that information in the decimal degrees format and in the Degrees Minutes Seconds format.\\ ​ \\ For those that don’t have the Desktop Edition, you will find the zip file “LatLongGraticuleServices” for the Service edition. It is using exactly the same GraticuleAdormentLayer class.\\ ​ \\ In the future, we will offer another class for graticule with more options for formatting and displaying the graticule. It will also offer projection support for map that are not in Decimal Degrees map unit.
-==== Native TAB File Suppport ====
-<div sampleitem>​
-{{desktopedition:​codesamples:​TabFileSupport.jpg?​300x180}}
-[[Source_Code_DesktopEditionSample_NativeTabFileSupport_CS_110524.zip|View Source]] |
-{{:​File:​DesktopEditionSample_NativeTabFileSupport_CS_110524.zip|C#​ Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\
-One of the most exciting new features in MapSuite 5.0 is native TAB file support. ​ In the past, the FDO extension was used for displaying TAB files in MapSuite. ​ Now with the new TabFeatureLayer,​ we have a simpler and more stable method of working with TAB files. ​ \\  \\ This Code Community project demonstrates how to load and display a TAB file using the new TabFeatureLayer. ​ The example also allows you to add, edit and delete features from the TAB file.
-==== Numbered Grid ====
-<div sampleitem>​
-{{desktopedition:​codesamples:​Map Suite Desktop Edition Sample Numbered Grid.jpg?​300x180}}
-[[Source_Code_DesktopEditionSample_NumberedGrid_CS_100622.zip|View Source]] |
-{{:​File:​DesktopEditionSample_NumberedGrid_CS_100622.zip|C#​ Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\
-==== Shapefile Encryption ====
-<div sampleitem>​
-{{:​no_screenshot.jpg?​300x180}}
-[[Source_Code_DesktopEditionSample_ShapefileEncryption_CS_100417.zip|View Source]] |
-{{:​File:​DesktopEditionSample_ShapefileEncryption_CS_100417.zip|C#​ Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\
-In today’s project, we are looking at a way to encrypt shapefiles to prevent them from being used outside the application. We show how to encrypt and decrypt shapefiles using streams. You will see that a very simple encryption algorithm is used but by looking at the example, you will be able to implement your own.\\ ​  \\ Disclaimer: This encryption system can be used only on small shapefiles due to the amount of memory used. A typical use would be to encrypt some valuable small shapefiles you don't want your users to access. In the future, Map Suite will provide a full encryption system as an API.
-{{page>​Map Suite Services Edition Layers FeatureSources Samples}}
map_suite_desktop_edition_layers_featuresources_samples.1442457107.txt.gz · Last modified: 2015/09/17 02:31 by admin
