map_suite_deployment_guide_deploying_applications
map_suite_deployment_guide_deploying_applications [2015/09/02 04:17]
admin [Latest Public Release (9.0.0.0)]
-====== Map Suite Deployment Guide Deploying Applications ======
-===== Deploying Applications =====
-Several Merge Modules are supplied to assist you in deploying all of our required dependencies. You can find them in the directory below.  ​
-===== Latest Public Release (9.0.0.0)=====
-  * \Shared Developer Reference\Merge Modules\MapSuiteEcw.msm ​
-  * \Shared Developer Reference\Merge Modules\MapSuiteFdoExtension.msm ​
-  * \Shared Developer Reference\Merge Modules\MapSuiteFileGeoDatabase.msm ​
-  * \Shared Developer Reference\Merge Modules\MapSuiteGeoRasterProjection.msm ​
-  * \Shared Developer Reference\Merge Modules\MapSuiteGeoTiff.msm ​
-  * \Shared Developer Reference\Merge Modules\MapSuiteMrSid.msm ​
-  * \Shared Developer Reference\Merge Modules\MapSuitePrjHelper.msm ​
-  * \Shared Developer Reference\Merge Modules\MapSuiteProj4.msm ​
-  * \Shared Developer Reference\Merge Modules\MapSuiteS57.msm ​
-  * \Shared Developer Reference\Merge Modules\Microsoft_VC100_CRT_x64.msm ​
-  * \Shared Developer Reference\Merge Modules\Microsoft_VC100_CRT_x86.msm ​
-  * \Shared Developer Reference\Merge Modules\Microsoft_VC100_DebugCRT_x64.msm ​
-  * \Shared Developer Reference\Merge Modules\Microsoft_VC100_DebugCRT_x86.msm ​
-  * \Shared Developer Reference\Merge Modules\MicrosoftSqlServerSpatial.msm ​
-**Notes:**
-MicrosoftSqlServerSpatial.msm*,​ Microsoft_VC100_CRT_x86.msm* and Microsoft_VC100_CRT_x64.msm* are always required. ​
-The main assemblies (such as MapSuiteCore.DLL,​ NetTopologySuite.DLL,​ GeoAPI.dll and CSScriptLibrary.dll) are not included in the Merge Modules, your project should automatically reference them and pull in these assemblies.
-MapSuiteGeoTiff.msm is not required if the GeoTiffRasterSource'​s LibraryType is ManagedLibTiff(By Default).
-MapSuiteProj4.msm is not required if Proj4Projection'​s MemoryMode is ManagedProj4Projection(By Default).
-MapSuiteFdoExtension.msm is not required if FdoExtension is not used.
-  * From Build 9.0.0.0 in Development Branch, the strong name File Geo Database merge module can be downloaded here: http://​wiki.thinkgeo.com/​wiki/​File:​MapSuiteFileGeoDatabaseStrongNameMergeModules2015-06-20.zip
-  * From Build 9.0.0.0 in Development Branch, the X86 Oracle merge module can be downloaded here: http://​wiki.thinkgeo.com/​wiki/​File:​MapSuiteOracleDependenciesMergeModuleX862015-06-20.zip
-  * From Build 9.0.0.0 in Development Branch, the X64 Oracle merge module can be downloaded here: http://​wiki.thinkgeo.com/​wiki/​File:​MapSuiteOracleDependenciesMergeModuleX642015-06-20.zip
-  * Form Build 9.0.13.0 in Development Branch, the merge modules can be downloaded here: http://​wiki.thinkgeo.com/​wiki/​File:​MapSuiteUpdatedMergeModules2015-07-06.zip
-  * Form Build 9.0.0.0 in Development Branch, the merge modules can be downloaded here: http://​wiki.thinkgeo.com/​wiki/​File:​MapSuiteUpdatedMergeModules2015-06-20.zip
-  * From Build 9.0.0.0 in Development Branch, the MapSuite Cad X86 merge module can be downloaded here: http://​wiki.thinkgeo.com/​wiki/​File:​MapSuiteCadX862015-06-20.zip
-  * From Build 9.0.0.0 in Development Branch, the MapSuite Cad X64 merge module can be downloaded here: http://​wiki.thinkgeo.com/​wiki/​File:​MapSuiteCadX642015-06-20.zip
-===== Map Suite Depolyment Guide of Previous Versions =====
-[[http://​wiki.thinkgeo.com/​wiki/​Map_Suite_Deployment_Guide_8.0.0.0|8.0.0.0]]
-[[http://​wiki.thinkgeo.com/​wiki/​Map_Suite_Deployment_Guide_7.0.0.0|7.0.0.0]]
-[[http://​wiki.thinkgeo.com/​wiki/​Map_Suite_Deployment_Guide_6.0.0.0|6.0.0.0]]
-[[Category:​Map Suite Services Edition]] [[Category:​Web GIS]] [[Category:​Desktop GIS]] [[Category:​GIS]] [[Category:​.NET]]
map_suite_deployment_guide_deploying_applications.1441167435.txt.gz ยท Last modified: 2015/09/02 04:17 by admin
