data_join_wizard [2015/09/28 08:16] admin [Step 3 - Select Columns to Join On] |
data_join_wizard [2015/09/28 08:22] (current) admin |
Line 24: | Line 24: | ||
===== Step 3 - Select Columns to Join On ===== | ===== Step 3 - Select Columns to Join On ===== | ||
- | <div imagewithremaker> | + | <div imagewithremaker right width250> |
{{ wiki:DataJoin_tbl1.png ?250|Using 'Product' column as the common data}} | {{ wiki:DataJoin_tbl1.png ?250|Using 'Product' column as the common data}} | ||
Using 'Product' column as the common data | Using 'Product' column as the common data | ||
Line 32: | Line 31: | ||
===== Step 4 - Configure the Output ===== | ===== Step 4 - Configure the Output ===== | ||
+ | <div imagewithremaker right width250> | ||
{{wiki:DataJoin_Result.png ?250|Result of Data Join with columns from both files added}} | {{wiki:DataJoin_Result.png ?250|Result of Data Join with columns from both files added}} | ||
+ | Result of Data Join with columns from both files added | ||
Step 4 of the Data Join Wizard allows users to select which data to include in the output layer. This step has an Available Columns list box on the left which allows users to see all columns from the input layer and delimited file. Users can use the All checkbox to select all, or the filter select box to only show columns from either the input layer or delimited file. Users can then select the necessary columns and press the right arrow (-->) button to add the columns into the Columns to Include list box. Once the user has the necessary columns in the Columns to Include list box, they can press Next > to proceed to Step 5. | Step 4 of the Data Join Wizard allows users to select which data to include in the output layer. This step has an Available Columns list box on the left which allows users to see all columns from the input layer and delimited file. Users can use the All checkbox to select all, or the filter select box to only show columns from either the input layer or delimited file. Users can then select the necessary columns and press the right arrow (-->) button to add the columns into the Columns to Include list box. Once the user has the necessary columns in the Columns to Include list box, they can press Next > to proceed to Step 5. | ||
