advanced_style
advanced_style [2015/09/29 03:51]
admin created
advanced_style [2015/09/29 03:51] (current)
Line 15: Line 15:
 | SquareAnchor | Applies a square cap that is larger than the line thickness. | {{wiki:Cap - SquareAnchor.png}} |  | SquareAnchor | Applies a square cap that is larger than the line thickness. | {{wiki:Cap - SquareAnchor.png}} |
 | Triangle | Applies a triangular (pointed) cap. | {{wiki:Cap - Triangle.png}} |  | Triangle | Applies a triangular (pointed) cap. | {{wiki:Cap - Triangle.png}} |
-Line Join - Determines what type of joint to draw at the point where one line ends and another begins. The following joint types are available:+
 +**Line Join** - Determines what type of joint to draw at the point where one line ends and another begins. The following joint types are available:
 ^Option ^ Description ^ Example ^ ^Option ^ Description ^ Example ^
advanced_style.1443498663.txt.gz · Last modified: 2015/09/29 03:51 by admin
