thinkgeo.mapsuite.wpfdesktopedition.popup
thinkgeo.mapsuite.wpfdesktopedition.popup [2015/09/18 03:15]
-====== ThinkGeo.MapSuite.WpfDesktopEdition.Popup ======
-This class represents a popup control for placing on the map.
-  *System.Object
-    *System.Windows.Threading.DispatcherObject
-      *System.Windows.DependencyObject
-        *System.Windows.Media.Visual
-          *System.Windows.UIElement
-            *System.Windows.FrameworkElement
-              *System.Windows.Controls.Control
-                *System.Windows.Controls.ContentControl
-                  ***ThinkGeo.MapSuite.WpfDesktopEdition.Popup**
-** {{wiki:​PublicMethod.gif|}} Popup() **
-This is constructor of Popup class.
-== Remarks ==
-N/A
-== Parameters ==
-<div newline></​div>​
-** {{wiki:​PublicMethod.gif|}} Popup(Double,​Double) **
-== Remarks ==
-N/A
-== Parameters ==
-  * //​longitude//​
-    * Type:Double
-    * Description:​This is longitude of the popup.
-  * //​latitude//​
-    * Type:Double
-    * Description:​This is latitude of the popup.
-** {{wiki:​PublicMethod.gif|}} Popup(PointShape) **
-== Remarks ==
-N/A
-== Parameters ==
-  * //​position//​
-    * Type:​[[ThinkGeo.MapSuite.Core.PointShape|PointShape]]
-    * Description:​This parameter indicates the position of the popup.
-** {{wiki:​PublicMethod.gif|}} Popup(Point) **
-== Remarks ==
-N/A
-== Parameters ==
-  * //​position//​
-    * Type:Point
-** {{wiki:​PublicMethod.gif|}} Draw(RectangleShape,​Double,​Double) **
-This method draws current popup on the PopupOverlay.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-  * Description:​N/​A
-== Parameters ==
-  * //​targetExtent//​
-    * Type:​[[ThinkGeo.MapSuite.Core.RectangleShape|RectangleShape]]
-    * Description:​This parameter indicates the extent that to place the popup.
-  * //​drawingScreenWidth//​
-    * Type:Double
-    * Description:​This parameter indicates the screen width of the map.
-  * //​drawingScreenHeight//​
-    * Type:Double
-    * Description:​This parameter indicates the screen height of the map.
-** {{wiki:​PublicMethod.gif|}} OnApplyTemplate() **
-When overridden in a derived class, is invoked whenever application code or internal processes call System.Windows.FrameworkElement.ApplyTemplate().
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} ShouldSerializeContent() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:String
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} ShouldSerializeStyle() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} ApplyTemplate() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} BeginStoryboard(Storyboard) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​storyboard//​
-    * Type:​Storyboard
-** {{wiki:​PublicMethod.gif|}} BeginStoryboard(Storyboard,​HandoffBehavior) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​handoffBehavior//​
-    * Type:​HandoffBehavior
-** {{wiki:​PublicMethod.gif|}} BeginStoryboard(Storyboard,​HandoffBehavior,​Boolean) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​isControllable//​
-    * Type:​Boolean
-** {{wiki:​PublicMethod.gif|}} ShouldSerializeTriggers() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} ShouldSerializeResources() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} FindResource(Object) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Object
-== Parameters ==
-  * //​resourceKey//​
-    * Type:Object
-** {{wiki:​PublicMethod.gif|}} TryFindResource(Object) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Object
-== Parameters ==
-    * Type:Object
-** {{wiki:​PublicMethod.gif|}} SetResourceReference(DependencyProperty,​Object) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-    * Type:​DependencyProperty
-  * //name//
-    * Type:Object
-** {{wiki:​PublicMethod.gif|}} GetBindingExpression(DependencyProperty) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​BindingExpression
-== Parameters ==
-  * //dp//
-** {{wiki:​PublicMethod.gif|}} SetBinding(DependencyProperty,​BindingBase) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​BindingExpressionBase
-== Parameters ==
-  * //dp//
-  * //binding//
-    * Type:​BindingBase
-** {{wiki:​PublicMethod.gif|}} SetBinding(DependencyProperty,​String) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-  * //dp//
-  * //path//
-    * Type:String
-** {{wiki:​PublicMethod.gif|}} BringIntoView() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} BringIntoView(Rect) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​targetRectangle//​
-    * Type:Rect
-** {{wiki:​PublicMethod.gif|}} MoveFocus(TraversalRequest) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //request//
-    * Type:​TraversalRequest
-** {{wiki:​PublicMethod.gif|}} PredictFocus(FocusNavigationDirection) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​DependencyObject
-== Parameters ==
-  * //​direction//​
-    * Type:​FocusNavigationDirection
-** {{wiki:​PublicMethod.gif|}} BeginInit() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} EndInit() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} RegisterName(String,​Object) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //name//
-    * Type:String
-  * //​scopedElement//​
-    * Type:Object
-** {{wiki:​PublicMethod.gif|}} UnregisterName(String) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //name//
-    * Type:String
-** {{wiki:​PublicMethod.gif|}} FindName(String) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Object
-== Parameters ==
-  * //name//
-    * Type:String
-** {{wiki:​PublicMethod.gif|}} UpdateDefaultStyle() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} ApplyAnimationClock(DependencyProperty,​AnimationClock) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-  * //clock//
-    * Type:​AnimationClock
-** {{wiki:​PublicMethod.gif|}} ApplyAnimationClock(DependencyProperty,​AnimationClock,​HandoffBehavior) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-  * //clock//
-** {{wiki:​PublicMethod.gif|}} BeginAnimation(DependencyProperty,​AnimationTimeline) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-  * //​animation//​
-    * Type:​AnimationTimeline
-** {{wiki:​PublicMethod.gif|}} BeginAnimation(DependencyProperty,​AnimationTimeline,​HandoffBehavior) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-  * //​animation//​
-** {{wiki:​PublicMethod.gif|}} GetAnimationBaseValue(DependencyProperty) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Object
-== Parameters ==
-  * //dp//
-** {{wiki:​PublicMethod.gif|}} ShouldSerializeInputBindings() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} ShouldSerializeCommandBindings() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} RaiseEvent(RoutedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​RoutedEventArgs
-** {{wiki:​PublicMethod.gif|}} AddHandler(RoutedEvent,​Delegate) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​routedEvent//​
-  * //handler//
-    * Type:​Delegate
-** {{wiki:​PublicMethod.gif|}} AddHandler(RoutedEvent,​Delegate,​Boolean) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //handler//
-    * Type:​Delegate
-  * //​handledEventsToo//​
-    * Type:​Boolean
-** {{wiki:​PublicMethod.gif|}} RemoveHandler(RoutedEvent,​Delegate) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //handler//
-    * Type:​Delegate
-** {{wiki:​PublicMethod.gif|}} AddToEventRoute(EventRoute,​RoutedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //route//
-    * Type:​EventRoute
-  * //e//
-** {{wiki:​PublicMethod.gif|}} InvalidateMeasure() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} InvalidateArrange() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} InvalidateVisual() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} Measure(Size) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​availableSize//​
-    * Type:Size
-** {{wiki:​PublicMethod.gif|}} Arrange(Rect) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​finalRect//​
-    * Type:Rect
-** {{wiki:​PublicMethod.gif|}} UpdateLayout() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} TranslatePoint(Point,​UIElement) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Point
-== Parameters ==
-  * //point//
-    * Type:Point
-  * //​relativeTo//​
-    * Type:​UIElement
-** {{wiki:​PublicMethod.gif|}} InputHitTest(Point) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​IInputElement
-== Parameters ==
-  * //point//
-    * Type:Point
-** {{wiki:​PublicMethod.gif|}} CaptureMouse() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} ReleaseMouseCapture() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} CaptureStylus() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} ReleaseStylusCapture() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} Focus() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} CaptureTouch(TouchDevice) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //​touchDevice//​
-    * Type:​TouchDevice
-** {{wiki:​PublicMethod.gif|}} ReleaseTouchCapture(TouchDevice) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} ReleaseAllTouchCaptures() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} IsAncestorOf(DependencyObject) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //​descendant//​
-** {{wiki:​PublicMethod.gif|}} IsDescendantOf(DependencyObject) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //​ancestor//​
-** {{wiki:​PublicMethod.gif|}} FindCommonVisualAncestor(DependencyObject) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-  * //​otherVisual//​
-** {{wiki:​PublicMethod.gif|}} TransformToAncestor(Visual) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​GeneralTransform
-== Parameters ==
-  * //​ancestor//​
-    * Type:Visual
-** {{wiki:​PublicMethod.gif|}} TransformToAncestor(Visual3D) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​GeneralTransform2DTo3D
-== Parameters ==
-  * //​ancestor//​
-    * Type:​Visual3D
-** {{wiki:​PublicMethod.gif|}} TransformToDescendant(Visual) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-    * Type:Visual
-** {{wiki:​PublicMethod.gif|}} TransformToVisual(Visual) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-  * //visual//
-    * Type:Visual
-** {{wiki:​PublicMethod.gif|}} PointToScreen(Point) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Point
-== Parameters ==
-  * //point//
-    * Type:Point
-** {{wiki:​PublicMethod.gif|}} PointFromScreen(Point) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Point
-== Parameters ==
-  * //point//
-    * Type:Point
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //obj//
-    * Type:Object
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} GetValue(DependencyProperty) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Object
-== Parameters ==
-  * //dp//
-** {{wiki:​PublicMethod.gif|}} SetValue(DependencyProperty,​Object) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-  * //value//
-    * Type:Object
-** {{wiki:​PublicMethod.gif|}} SetCurrentValue(DependencyProperty,​Object) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-  * //value//
-    * Type:Object
-** {{wiki:​PublicMethod.gif|}} SetValue(DependencyPropertyKey,​Object) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //key//
-    * Type:​DependencyPropertyKey
-  * //value//
-    * Type:Object
-** {{wiki:​PublicMethod.gif|}} ClearValue(DependencyProperty) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-** {{wiki:​PublicMethod.gif|}} ClearValue(DependencyPropertyKey) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //key//
-** {{wiki:​PublicMethod.gif|}} CoerceValue(DependencyProperty) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-** {{wiki:​PublicMethod.gif|}} InvalidateProperty(DependencyProperty) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-** {{wiki:​PublicMethod.gif|}} ReadLocalValue(DependencyProperty) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Object
-== Parameters ==
-  * //dp//
-** {{wiki:​PublicMethod.gif|}} GetLocalValueEnumerator() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​LocalValueEnumerator
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} CheckAccess() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} VerifyAccess() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Type
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} DrawCore() **
-This method draws popup on the PopupOverlay.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} OnPositionChanged(DependencyPropertyChangedEventArgs) **
-This method raises when the Position property is changed.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​eventArgs//​
-    * Type:​DependencyPropertyChangedEventArgs
-** {{wiki:​ProtectedMethod.gif|}} OnArrowHeightChanged(DependencyPropertyChangedEventArgs) **
-Raises the  event when the ArrowHeight property is changed.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //args//
-    * Description:​The ​ instance containing the event data.
-** {{wiki:​ProtectedMethod.gif|}} OnPropertyChanged(DependencyPropertyChangedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} GetPlainText() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:String
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} PrepareContentControl(Object,​DataTemplate,​DataTemplateSelector,​String) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //item//
-    * Type:Object
-  * //​itemTemplate//​
-    * Type:​DataTemplate
-  * //​itemTemplateSelector//​
-    * Type:​DataTemplateSelector
-  * //​itemStringFormat//​
-    * Type:String
-** {{wiki:​ProtectedMethod.gif|}} ClearContentControl(Object) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //item//
-    * Type:Object
-** {{wiki:​ProtectedMethod.gif|}} AddChild(Object) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //value//
-    * Type:Object
-** {{wiki:​ProtectedMethod.gif|}} AddText(String) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //text//
-    * Type:String
-** {{wiki:​ProtectedMethod.gif|}} OnContentChanged(Object,​Object) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​oldContent//​
-    * Type:Object
-  * //​newContent//​
-    * Type:Object
-** {{wiki:​ProtectedMethod.gif|}} OnContentTemplateChanged(DataTemplate,​DataTemplate) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​oldContentTemplate//​
-  * //​newContentTemplate//​
-** {{wiki:​ProtectedMethod.gif|}} OnContentTemplateSelectorChanged(DataTemplateSelector,​DataTemplateSelector) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​oldContentTemplateSelector//​
-  * //​newContentTemplateSelector//​
-** {{wiki:​ProtectedMethod.gif|}} OnContentStringFormatChanged(String,​String) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​oldContentStringFormat//​
-    * Type:String
-  * //​newContentStringFormat//​
-    * Type:String
-** {{wiki:​ProtectedMethod.gif|}} OnTemplateChangedInternal(FrameworkTemplate,​FrameworkTemplate) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​oldTemplate//​
-    * Type:​FrameworkTemplate
-  * //​newTemplate//​
-** {{wiki:​ProtectedMethod.gif|}} OnTemplateChanged(ControlTemplate,​ControlTemplate) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-    * Type:​ControlTemplate
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewMouseDoubleClick(MouseButtonEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​MouseButtonEventArgs
-** {{wiki:​ProtectedMethod.gif|}} OnMouseDoubleClick(MouseButtonEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreApplyTemplate() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} OnPostApplyTemplate() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} UpdateVisualState() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} UpdateVisualState(Boolean) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​useTransitions//​
-    * Type:​Boolean
-** {{wiki:​ProtectedMethod.gif|}} ChangeVisualState(Boolean) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-    * Type:​Boolean
-** {{wiki:​ProtectedMethod.gif|}} ChangeValidationVisualState(Boolean) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-    * Type:​Boolean
-** {{wiki:​ProtectedMethod.gif|}} MeasureOverride(Size) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Size
-== Parameters ==
-  * //​constraint//​
-    * Type:Size
-** {{wiki:​ProtectedMethod.gif|}} ArrangeOverride(Size) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Size
-== Parameters ==
-  * //​arrangeBounds//​
-    * Type:Size
-** {{wiki:​ProtectedMethod.gif|}} ReadControlFlag(ControlBoolFlags) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //reqFlag//
-    * Type:​ControlBoolFlags
-** {{wiki:​ProtectedMethod.gif|}} WriteControlFlag(ControlBoolFlags,​Boolean) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //reqFlag//
-  * //set//
-    * Type:​Boolean
-** {{wiki:​ProtectedMethod.gif|}} OnStyleChanged(Style,​Style) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​oldStyle//​
-    * Type:Style
-  * //​newStyle//​
-    * Type:Style
-** {{wiki:​ProtectedMethod.gif|}} ParentLayoutInvalidated(UIElement) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //child//
-    * Type:​UIElement
-** {{wiki:​ProtectedMethod.gif|}} GetVisualChild(Int32) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Visual
-== Parameters ==
-  * //index//
-    * Type:Int32
-** {{wiki:​ProtectedMethod.gif|}} GetTemplateChild(String) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-  * //​childName//​
-    * Type:String
-** {{wiki:​ProtectedMethod.gif|}} HasNonDefaultValue(DependencyProperty) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //dp//
-** {{wiki:​ProtectedMethod.gif|}} EvaluateBaseValueCore(DependencyProperty,​PropertyMetadata,​EffectiveValueEntry&​) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-  * //​metadata//​
-    * Type:​PropertyMetadata
-  * //​newEntry//​
-    * Type:​EffectiveValueEntry&​
-** {{wiki:​ProtectedMethod.gif|}} GetRawValue(DependencyProperty,​PropertyMetadata,​EffectiveValueEntry&​) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-  * //​metadata//​
-  * //entry//
-** {{wiki:​ProtectedMethod.gif|}} GetExpressionCore(DependencyProperty,​PropertyMetadata) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Expression
-== Parameters ==
-  * //dp//
-  * //​metadata//​
-** {{wiki:​ProtectedMethod.gif|}} pushTextRenderingMode() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} OnAncestorChanged() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} OnVisualParentChanged(DependencyObject) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​oldParent//​
-** {{wiki:​ProtectedMethod.gif|}} OnVisualAncestorChanged(Object,​AncestorChangedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //sender//
-    * Type:Object
-  * //e//
-    * Type:​AncestorChangedEventArgs
-** {{wiki:​ProtectedMethod.gif|}} GetUIParentCore() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} AdjustEventSource(RoutedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Object
-== Parameters ==
-  * //args//
-** {{wiki:​ProtectedMethod.gif|}} AdjustBranchSource(RoutedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //args//
-** {{wiki:​ProtectedMethod.gif|}} BuildRouteCore(EventRoute,​RoutedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //route//
-  * //args//
-** {{wiki:​ProtectedMethod.gif|}} BuildRouteCoreHelper(EventRoute,​RoutedEventArgs,​Boolean) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //route//
-  * //args//
-  * //​shouldAddIntermediateElementsToRoute//​
-    * Type:​Boolean
-** {{wiki:​ProtectedMethod.gif|}} AddToEventRouteCore(EventRoute,​RoutedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //route//
-  * //args//
-** {{wiki:​ProtectedMethod.gif|}} IgnoreModelParentBuildRoute(RoutedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //args//
-** {{wiki:​ProtectedMethod.gif|}} InvalidateAutomationAncestorsCore(Stack<​DependencyObject>,​Boolean&​) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //​branchNodeStack//​
-    * Type:​Stack<​DependencyObject>​
-  * //​continuePastCoreTree//​
-    * Type:​Boolean&​
-** {{wiki:​ProtectedMethod.gif|}} InvalidateAutomationAncestorsCoreHelper(Stack<​DependencyObject>,​Boolean&,​Boolean) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-    * Type:​Boolean&​
-  * //​shouldInvalidateIntermediateElements//​
-    * Type:​Boolean
-** {{wiki:​ProtectedMethod.gif|}} MeasureCore(Size) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Size
-== Parameters ==
-    * Type:Size
-** {{wiki:​ProtectedMethod.gif|}} ArrangeCore(Rect) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​finalRect//​
-    * Type:Rect
-** {{wiki:​ProtectedMethod.gif|}} OnRenderSizeChanged(SizeChangedInfo) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​sizeInfo//​
-    * Type:​SizeChangedInfo
-** {{wiki:​ProtectedMethod.gif|}} GetLayoutClip(Size) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Geometry
-== Parameters ==
-  * //​layoutSlotSize//​
-    * Type:Size
-** {{wiki:​ProtectedMethod.gif|}} GetLayoutClipInternal() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Geometry
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} OnGotFocus(RoutedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnInitialized(EventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​EventArgs
-** {{wiki:​ProtectedMethod.gif|}} OnPresentationSourceChanged(Boolean) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​attached//​
-    * Type:​Boolean
-** {{wiki:​ProtectedMethod.gif|}} OnAddHandler(RoutedEvent,​Delegate) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //handler//
-    * Type:​Delegate
-** {{wiki:​ProtectedMethod.gif|}} OnRemoveHandler(RoutedEvent,​Delegate) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //handler//
-    * Type:​Delegate
-** {{wiki:​ProtectedMethod.gif|}} OnLoaded(RoutedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //args//
-** {{wiki:​ProtectedMethod.gif|}} OnUnloaded(RoutedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //args//
-** {{wiki:​ProtectedMethod.gif|}} AddSynchronizedInputPreOpportunityHandlerCore(EventRoute,​RoutedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //route//
-  * //args//
-** {{wiki:​ProtectedMethod.gif|}} RaiseClrEvent(EventPrivateKey,​EventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //key//
-    * Type:​EventPrivateKey
-  * //args//
-    * Type:​EventArgs
-** {{wiki:​ProtectedMethod.gif|}} OnToolTipOpening(ToolTipEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​ToolTipEventArgs
-** {{wiki:​ProtectedMethod.gif|}} OnToolTipClosing(ToolTipEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnContextMenuOpening(ContextMenuEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​ContextMenuEventArgs
-** {{wiki:​ProtectedMethod.gif|}} OnContextMenuClosing(ContextMenuEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} EventHandlersStoreAdd(EventPrivateKey,​Delegate) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //key//
-  * //handler//
-    * Type:​Delegate
-** {{wiki:​ProtectedMethod.gif|}} EventHandlersStoreRemove(EventPrivateKey,​Delegate) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //key//
-  * //handler//
-    * Type:​Delegate
-** {{wiki:​ProtectedMethod.gif|}} ReadInternalFlag(InternalFlags) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //reqFlag//
-    * Type:​InternalFlags
-** {{wiki:​ProtectedMethod.gif|}} ReadInternalFlag2(InternalFlags2) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //reqFlag//
-    * Type:​InternalFlags2
-** {{wiki:​ProtectedMethod.gif|}} WriteInternalFlag(InternalFlags,​Boolean) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //reqFlag//
-  * //set//
-    * Type:​Boolean
-** {{wiki:​ProtectedMethod.gif|}} WriteInternalFlag2(InternalFlags2,​Boolean) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //reqFlag//
-  * //set//
-    * Type:​Boolean
-** {{wiki:​ProtectedMethod.gif|}} FindName(String,​DependencyObject&​) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Object
-== Parameters ==
-  * //name//
-    * Type:String
-  * //​scopeOwner//​
-    * Type:​DependencyObject&​
-** {{wiki:​ProtectedMethod.gif|}} FindResourceOnSelf(Object,​Boolean,​Boolean) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Object
-== Parameters ==
-    * Type:Object
-  * //​allowDeferredResourceReference//​
-    * Type:​Boolean
-  * //​mustReturnDeferredResourceReference//​
-    * Type:​Boolean
-** {{wiki:​ProtectedMethod.gif|}} ContextVerifiedGetParent() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} AddLogicalChild(Object) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //child//
-    * Type:Object
-** {{wiki:​ProtectedMethod.gif|}} RemoveLogicalChild(Object) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //child//
-    * Type:Object
-** {{wiki:​ProtectedMethod.gif|}} ChangeLogicalParent(DependencyObject) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​newParent//​
-** {{wiki:​ProtectedMethod.gif|}} OnNewParent(DependencyObject) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​newParent//​
-** {{wiki:​ProtectedMethod.gif|}} OnAncestorChangedInternal(TreeChangeInfo) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​parentTreeState//​
-    * Type:​TreeChangeInfo
-** {{wiki:​ProtectedMethod.gif|}} InvalidateTreeDependentProperties(TreeChangeInfo,​Boolean) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​FrugalObjectList<​DependencyProperty>​
-== Parameters ==
-  * //​isSelfInheritanceParent//​
-    * Type:​Boolean
-** {{wiki:​ProtectedMethod.gif|}} UpdateStyleProperty() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} UpdateThemeStyleProperty() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} OnThemeChanged() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} FireLoadedOnDescendentsInternal() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} FireUnloadedOnDescendentsInternal() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} ShouldProvideInheritanceContext(DependencyObject,​DependencyProperty) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //target//
-  * //​property//​
-** {{wiki:​ProtectedMethod.gif|}} AddInheritanceContext(DependencyObject,​DependencyProperty) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //context//
-  * //​property//​
-** {{wiki:​ProtectedMethod.gif|}} RemoveInheritanceContext(DependencyObject,​DependencyProperty) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //context//
-  * //​property//​
-** {{wiki:​ProtectedMethod.gif|}} OnInheritanceContextChangedCore(EventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //args//
-    * Type:​EventArgs
-** {{wiki:​ProtectedMethod.gif|}} ChangeSubtreeHasLoadedChangedHandler(DependencyObject) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //mentor//
-** {{wiki:​ProtectedMethod.gif|}} RaiseInheritedPropertyChangedEvent(InheritablePropertyChangeInfo&​) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //info//
-    * Type:​InheritablePropertyChangeInfo&​
-** {{wiki:​ProtectedMethod.gif|}} EvaluateAnimatedValueCore(DependencyProperty,​PropertyMetadata,​EffectiveValueEntry&​) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-  * //​metadata//​
-  * //entry//
-** {{wiki:​ProtectedMethod.gif|}} BuildRoute(EventRoute,​RoutedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //route//
-  * //args//
-** {{wiki:​ProtectedMethod.gif|}} RaiseEvent(RoutedEventArgs,​Boolean) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //args//
-  * //trusted//
-    * Type:​Boolean
-** {{wiki:​ProtectedMethod.gif|}} RaiseTrustedEvent(RoutedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //args//
-** {{wiki:​ProtectedMethod.gif|}} EnsureEventHandlersStore() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewMouseDown(MouseButtonEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnMouseDown(MouseButtonEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewMouseUp(MouseButtonEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnMouseUp(MouseButtonEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewMouseLeftButtonDown(MouseButtonEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnMouseLeftButtonDown(MouseButtonEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewMouseLeftButtonUp(MouseButtonEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnMouseLeftButtonUp(MouseButtonEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewMouseRightButtonDown(MouseButtonEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnMouseRightButtonDown(MouseButtonEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewMouseRightButtonUp(MouseButtonEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnMouseRightButtonUp(MouseButtonEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewMouseMove(MouseEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​MouseEventArgs
-** {{wiki:​ProtectedMethod.gif|}} OnMouseMove(MouseEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewMouseWheel(MouseWheelEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​MouseWheelEventArgs
-** {{wiki:​ProtectedMethod.gif|}} OnMouseWheel(MouseWheelEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnMouseEnter(MouseEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnMouseLeave(MouseEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnGotMouseCapture(MouseEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnLostMouseCapture(MouseEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnQueryCursor(QueryCursorEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​QueryCursorEventArgs
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewStylusDown(StylusDownEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​StylusDownEventArgs
-** {{wiki:​ProtectedMethod.gif|}} OnStylusDown(StylusDownEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewStylusUp(StylusEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​StylusEventArgs
-** {{wiki:​ProtectedMethod.gif|}} OnStylusUp(StylusEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewStylusMove(StylusEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnStylusMove(StylusEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewStylusInAirMove(StylusEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnStylusInAirMove(StylusEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnStylusEnter(StylusEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnStylusLeave(StylusEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewStylusInRange(StylusEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnStylusInRange(StylusEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewStylusOutOfRange(StylusEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnStylusOutOfRange(StylusEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewStylusSystemGesture(StylusSystemGestureEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​StylusSystemGestureEventArgs
-** {{wiki:​ProtectedMethod.gif|}} OnStylusSystemGesture(StylusSystemGestureEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnGotStylusCapture(StylusEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnLostStylusCapture(StylusEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnStylusButtonDown(StylusButtonEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​StylusButtonEventArgs
-** {{wiki:​ProtectedMethod.gif|}} OnStylusButtonUp(StylusButtonEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewStylusButtonDown(StylusButtonEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewStylusButtonUp(StylusButtonEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewKeyDown(KeyEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​KeyEventArgs
-** {{wiki:​ProtectedMethod.gif|}} OnKeyDown(KeyEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewKeyUp(KeyEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnKeyUp(KeyEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewGotKeyboardFocus(KeyboardFocusChangedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​KeyboardFocusChangedEventArgs
-** {{wiki:​ProtectedMethod.gif|}} OnGotKeyboardFocus(KeyboardFocusChangedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewLostKeyboardFocus(KeyboardFocusChangedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnLostKeyboardFocus(KeyboardFocusChangedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewTextInput(TextCompositionEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​TextCompositionEventArgs
-** {{wiki:​ProtectedMethod.gif|}} OnTextInput(TextCompositionEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewQueryContinueDrag(QueryContinueDragEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​QueryContinueDragEventArgs
-** {{wiki:​ProtectedMethod.gif|}} OnQueryContinueDrag(QueryContinueDragEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewGiveFeedback(GiveFeedbackEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​GiveFeedbackEventArgs
-** {{wiki:​ProtectedMethod.gif|}} OnGiveFeedback(GiveFeedbackEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewDragEnter(DragEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​DragEventArgs
-** {{wiki:​ProtectedMethod.gif|}} OnDragEnter(DragEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewDragOver(DragEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnDragOver(DragEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewDragLeave(DragEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnDragLeave(DragEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewDrop(DragEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnDrop(DragEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewTouchDown(TouchEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​TouchEventArgs
-** {{wiki:​ProtectedMethod.gif|}} OnTouchDown(TouchEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewTouchMove(TouchEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnTouchMove(TouchEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnPreviewTouchUp(TouchEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnTouchUp(TouchEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnGotTouchCapture(TouchEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnLostTouchCapture(TouchEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnTouchEnter(TouchEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnTouchLeave(TouchEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnIsMouseDirectlyOverChanged(DependencyPropertyChangedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnIsKeyboardFocusWithinChanged(DependencyPropertyChangedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} RaiseIsKeyboardFocusWithinChanged(DependencyPropertyChangedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //args//
-** {{wiki:​ProtectedMethod.gif|}} OnIsMouseCapturedChanged(DependencyPropertyChangedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnIsMouseCaptureWithinChanged(DependencyPropertyChangedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} RaiseIsMouseCaptureWithinChanged(DependencyPropertyChangedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //args//
-** {{wiki:​ProtectedMethod.gif|}} OnIsStylusDirectlyOverChanged(DependencyPropertyChangedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnIsStylusCapturedChanged(DependencyPropertyChangedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnIsStylusCaptureWithinChanged(DependencyPropertyChangedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} RaiseIsStylusCaptureWithinChanged(DependencyPropertyChangedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //args//
-** {{wiki:​ProtectedMethod.gif|}} OnIsKeyboardFocusedChanged(DependencyPropertyChangedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} ReadFlag(CoreFlags) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //field//
-    * Type:​CoreFlags
-** {{wiki:​ProtectedMethod.gif|}} WriteFlag(CoreFlags,​Boolean) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //field//
-    * Type:​CoreFlags
-  * //value//
-    * Type:​Boolean
-** {{wiki:​ProtectedMethod.gif|}} InvalidateMeasureInternal() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} InvalidateArrangeInternal() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} OnChildDesiredSizeChanged(UIElement) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //child//
-    * Type:​UIElement
-** {{wiki:​ProtectedMethod.gif|}} GetUIParentOrICH(UIElement&,​IContentHost&​) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​uiParent//​
-    * Type:​UIElement&​
-  * //ich//
-    * Type:​IContentHost&​
-** {{wiki:​ProtectedMethod.gif|}} GetUIParentWithinLayoutIsland() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​UIElement
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} OnRender(DrawingContext) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​drawingContext//​
-    * Type:​DrawingContext
-** {{wiki:​ProtectedMethod.gif|}} GetHitTestBounds() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Rect
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //sender//
-    * Type:Object
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} GetUIParent() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} GetUIParent(Boolean) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-  * //​continuePastVisualTree//​
-    * Type:​Boolean
-** {{wiki:​ProtectedMethod.gif|}} GetUIParentNo3DTraversal() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} AddSynchronizedInputPreOpportunityHandler(EventRoute,​RoutedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //route//
-  * //args//
-** {{wiki:​ProtectedMethod.gif|}} AddSynchronizedInputPostOpportunityHandler(EventRoute,​RoutedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //route//
-  * //args//
-** {{wiki:​ProtectedMethod.gif|}} SynchronizedInputPreOpportunityHandler(Object,​RoutedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //sender//
-    * Type:Object
-  * //args//
-** {{wiki:​ProtectedMethod.gif|}} SynchronizedInputPostOpportunityHandler(Object,​RoutedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //sender//
-    * Type:Object
-  * //args//
-** {{wiki:​ProtectedMethod.gif|}} StartListeningSynchronizedInput(SynchronizedInputType) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //​inputType//​
-    * Type:​SynchronizedInputType
-** {{wiki:​ProtectedMethod.gif|}} CancelSynchronizedInput() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} InputHitTest(Point,​IInputElement&,​IInputElement&​) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //pt//
-    * Type:Point
-  * //​enabledHit//​
-    * Type:​IInputElement&​
-  * //rawHit//
-** {{wiki:​ProtectedMethod.gif|}} InputHitTest(Point,​IInputElement&,​IInputElement&,​HitTestResult&​) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //pt//
-    * Type:Point
-  * //rawHit//
-  * //​rawHitResult//​
-    * Type:​HitTestResult&​
-** {{wiki:​ProtectedMethod.gif|}} SynchronizeReverseInheritPropertyFlags(DependencyObject,​Boolean) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​oldParent//​
-  * //​isCoreParent//​
-    * Type:​Boolean
-** {{wiki:​ProtectedMethod.gif|}} BlockReverseInheritance() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} OnAccessKey(AccessKeyEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​AccessKeyEventArgs
-** {{wiki:​ProtectedMethod.gif|}} HitTestCore(PointHitTestParameters) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-  * //​hitTestParameters//​
-    * Type:​PointHitTestParameters
-** {{wiki:​ProtectedMethod.gif|}} HitTestCore(GeometryHitTestParameters) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​GeometryHitTestResult
-== Parameters ==
-    * Type:​GeometryHitTestParameters
-** {{wiki:​ProtectedMethod.gif|}} RenderOpen() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} RenderClose(IDrawingContent) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-    * Type:​IDrawingContent
-** {{wiki:​ProtectedMethod.gif|}} FreeContent(Channel) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //channel//
-    * Type:​Channel
-** {{wiki:​ProtectedMethod.gif|}} GetContentBounds() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Rect
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} WalkContent(DrawingContextWalker) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //walker//
-    * Type:​DrawingContextWalker
-** {{wiki:​ProtectedMethod.gif|}} RenderContent(RenderContext,​Boolean) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //ctx//
-    * Type:​RenderContext
-  * //​isOnChannel//​
-    * Type:​Boolean
-** {{wiki:​ProtectedMethod.gif|}} GetDrawing() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​DrawingGroup
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} InvokeAccessKey(AccessKeyEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} OnLostFocus(RoutedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-** {{wiki:​ProtectedMethod.gif|}} UpdateIsVisibleCache() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} OnCreateAutomationPeer() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​AutomationPeer
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} CreateAutomationPeer() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} GetAutomationPeer() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} CreateGenericRootAutomationPeer() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} SetPersistId(Int32) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //value//
-    * Type:Int32
-** {{wiki:​ProtectedMethod.gif|}} OnManipulationStarting(ManipulationStartingEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​ManipulationStartingEventArgs
-** {{wiki:​ProtectedMethod.gif|}} OnManipulationStarted(ManipulationStartedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​ManipulationStartedEventArgs
-** {{wiki:​ProtectedMethod.gif|}} OnManipulationDelta(ManipulationDeltaEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​ManipulationDeltaEventArgs
-** {{wiki:​ProtectedMethod.gif|}} OnManipulationInertiaStarting(ManipulationInertiaStartingEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​ManipulationInertiaStartingEventArgs
-** {{wiki:​ProtectedMethod.gif|}} OnManipulationBoundaryFeedback(ManipulationBoundaryFeedbackEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​ManipulationBoundaryFeedbackEventArgs
-** {{wiki:​ProtectedMethod.gif|}} OnManipulationCompleted(ManipulationCompletedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​ManipulationCompletedEventArgs
-** {{wiki:​ProtectedMethod.gif|}} IsOnChannel(Channel) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //channel//
-    * Type:​Channel
-** {{wiki:​ProtectedMethod.gif|}} AddRefOnChannelCore(Channel) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​ResourceHandle
-== Parameters ==
-  * //channel//
-    * Type:​Channel
-** {{wiki:​ProtectedMethod.gif|}} ReleaseOnChannelCore(Channel) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //channel//
-    * Type:​Channel
-** {{wiki:​ProtectedMethod.gif|}} CalculateSubgraphBoundsInnerSpace() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Rect
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} CalculateSubgraphRenderBoundsInnerSpace() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Rect
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} CalculateSubgraphBoundsInnerSpace(Boolean) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Rect
-== Parameters ==
-  * //​renderBounds//​
-    * Type:​Boolean
-** {{wiki:​ProtectedMethod.gif|}} CalculateSubgraphBoundsOuterSpace() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Rect
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} CalculateSubgraphRenderBoundsOuterSpace() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Rect
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} AddRefOnChannelForCyclicBrush(ICyclicBrush,​Channel) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​cyclicBrush//​
-    * Type:​ICyclicBrush
-  * //channel//
-    * Type:​Channel
-** {{wiki:​ProtectedMethod.gif|}} ReleaseOnChannelForCyclicBrush(ICyclicBrush,​Channel) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //channel//
-    * Type:​Channel
-** {{wiki:​ProtectedMethod.gif|}} VerifyAPIReadOnly() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} VerifyAPIReadOnly(DependencyObject) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //value//
-** {{wiki:​ProtectedMethod.gif|}} VerifyAPIReadWrite() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} VerifyAPIReadWrite(DependencyObject) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //value//
-** {{wiki:​ProtectedMethod.gif|}} Precompute() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} PrecomputeContent() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} PrecomputeRecursive(Rect&​) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​bboxSubgraph//​
-    * Type:​Rect&​
-** {{wiki:​ProtectedMethod.gif|}} Render(RenderContext,​UInt32) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //ctx//
-  * //​childIndex//​
-    * Type:UInt32
-** {{wiki:​ProtectedMethod.gif|}} RenderRecursive(RenderContext) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //ctx//
-** {{wiki:​ProtectedMethod.gif|}} Enter() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} Exit() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} InvalidateHitTestBounds() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} HitTest(Point) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-  * //point//
-    * Type:Point
-<div newline></​div>​
-** {{wiki:​ProtectedMethod.gif|}} HitTest(Point,​Boolean) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-  * //point//
-    * Type:Point
-  * //​include2DOn3D//​
-    * Type:​Boolean
-** {{wiki:​ProtectedMethod.gif|}} HitTest(HitTestFilterCallback,​HitTestResultCallback,​HitTestParameters) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​filterCallback//​
-    * Type:​HitTestFilterCallback
-  * //​resultCallback//​
-    * Type:​HitTestResultCallback
-    * Type:​HitTestParameters
-** {{wiki:​ProtectedMethod.gif|}} HitTestPoint(HitTestFilterCallback,​HitTestResultCallback,​PointHitTestParameters) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​HitTestResultBehavior
-== Parameters ==
-  * //​pointParams//​
-** {{wiki:​ProtectedMethod.gif|}} TransformToOuterSpace() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Description:​N/​A
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} HitTestGeometry(HitTestFilterCallback,​HitTestResultCallback,​GeometryHitTestParameters) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-  * //​geometryParams//​
-** {{wiki:​ProtectedMethod.gif|}} HitTestPointInternal(HitTestFilterCallback,​HitTestResultCallback,​PointHitTestParameters) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} InternalGetVisualChild(Int32) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Visual
-== Parameters ==
-  * //index//
-    * Type:Int32
-** {{wiki:​ProtectedMethod.gif|}} InternalGet2DOr3DVisualChild(Int32) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-  * //index//
-    * Type:Int32
-** {{wiki:​ProtectedMethod.gif|}} InternalAddVisualChild(Visual) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //child//
-    * Type:Visual
-** {{wiki:​ProtectedMethod.gif|}} InternalRemoveVisualChild(Visual) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //child//
-    * Type:Visual
-** {{wiki:​ProtectedMethod.gif|}} AddVisualChild(Visual) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //child//
-    * Type:Visual
-** {{wiki:​ProtectedMethod.gif|}} RemoveVisualChild(Visual) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //child//
-    * Type:Visual
-** {{wiki:​ProtectedMethod.gif|}} InvalidateZOrder() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} InternalSetOffsetWorkaround(Vector) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //offset//
-    * Type:Vector
-** {{wiki:​ProtectedMethod.gif|}} InternalSetTransformWorkaround(Transform) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​transform//​
-    * Type:​Transform
-** {{wiki:​ProtectedMethod.gif|}} BitmapEffectEmulationChanged(Object,​EventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //sender//
-    * Type:Object
-  * //e//
-    * Type:​EventArgs
-** {{wiki:​ProtectedMethod.gif|}} ChangeVisualClip(Geometry,​Boolean) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //newClip//
-    * Type:​Geometry
-  * //​dontSetWhenClose//​
-    * Type:​Boolean
-** {{wiki:​ProtectedMethod.gif|}} DisconnectAttachedResource(VisualProxyFlags,​IResource) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​correspondingFlag//​
-    * Type:​VisualProxyFlags
-  * //​attachedResource//​
-    * Type:​IResource
-** {{wiki:​ProtectedMethod.gif|}} FireOnVisualParentChanged(DependencyObject) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​oldParent//​
-** {{wiki:​ProtectedMethod.gif|}} OnVisualChildrenChanged(DependencyObject,​DependencyObject) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​visualAdded//​
-  * //​visualRemoved//​
-** {{wiki:​ProtectedMethod.gif|}} SetFlagsToRoot(Boolean,​VisualFlags) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //value//
-    * Type:​Boolean
-  * //flag//
-    * Type:​VisualFlags
-** {{wiki:​ProtectedMethod.gif|}} FindFirstAncestorWithFlagsAnd(VisualFlags) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-  * //flag//
-** {{wiki:​ProtectedMethod.gif|}} TrySimpleTransformToAncestor(Visual,​Boolean,​GeneralTransform&,​Matrix&​) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //​ancestor//​
-    * Type:Visual
-  * //inverse//
-    * Type:​Boolean
-  * //​generalTransform//​
-    * Type:​GeneralTransform&​
-  * //​simpleTransform//​
-    * Type:​Matrix&​
-** {{wiki:​ProtectedMethod.gif|}} TrySimpleTransformToAncestor(Visual3D,​GeneralTransform2DTo3D&​) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //​ancestor//​
-    * Type:​Visual3D
-  * //​transformTo3D//​
-    * Type:​GeneralTransform2DTo3D&​
-** {{wiki:​ProtectedMethod.gif|}} ClipChanged(Object,​EventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //sender//
-    * Type:Object
-  * //e//
-    * Type:​EventArgs
-** {{wiki:​ProtectedMethod.gif|}} ScrollableAreaClipChanged(Object,​EventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //sender//
-    * Type:Object
-  * //e//
-    * Type:​EventArgs
-** {{wiki:​ProtectedMethod.gif|}} TransformChanged(Object,​EventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //sender//
-    * Type:Object
-  * //e//
-    * Type:​EventArgs
-** {{wiki:​ProtectedMethod.gif|}} EffectChanged(Object,​EventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //sender//
-    * Type:Object
-  * //e//
-    * Type:​EventArgs
-** {{wiki:​ProtectedMethod.gif|}} CacheModeChanged(Object,​EventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //sender//
-    * Type:Object
-  * //e//
-    * Type:​EventArgs
-** {{wiki:​ProtectedMethod.gif|}} GuidelinesChanged(Object,​EventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //sender//
-    * Type:Object
-  * //e//
-    * Type:​EventArgs
-** {{wiki:​ProtectedMethod.gif|}} OpacityMaskChanged(Object,​EventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //sender//
-    * Type:Object
-  * //e//
-    * Type:​EventArgs
-** {{wiki:​ProtectedMethod.gif|}} ContentsChanged(Object,​EventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //sender//
-    * Type:Object
-  * //e//
-    * Type:​EventArgs
-** {{wiki:​ProtectedMethod.gif|}} SetFlagsOnAllChannels(Boolean,​VisualProxyFlags) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //value//
-    * Type:​Boolean
-  * //​flagsToChange//​
-** {{wiki:​ProtectedMethod.gif|}} SetFlags(Channel,​Boolean,​VisualProxyFlags) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //channel//
-    * Type:​Channel
-  * //value//
-    * Type:​Boolean
-** {{wiki:​ProtectedMethod.gif|}} SetFlags(Boolean,​VisualFlags) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //value//
-    * Type:​Boolean
-  * //flags//
-** {{wiki:​ProtectedMethod.gif|}} CheckFlagsOnAllChannels(VisualProxyFlags) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //​flagsToCheck//​
-** {{wiki:​ProtectedMethod.gif|}} CheckFlagsAnd(Channel,​VisualProxyFlags) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //channel//
-    * Type:​Channel
-** {{wiki:​ProtectedMethod.gif|}} CheckFlagsAnd(VisualFlags) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //flags//
-** {{wiki:​ProtectedMethod.gif|}} CheckFlagsOr(Channel,​VisualProxyFlags) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //channel//
-    * Type:​Channel
-** {{wiki:​ProtectedMethod.gif|}} CheckFlagsOr(VisualFlags) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //flags//
-** {{wiki:​ProtectedMethod.gif|}} PropagateChangedFlags() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} Seal() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} GetValueEntry(EntryIndex,​DependencyProperty,​PropertyMetadata,​RequestFlags) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-  * //​entryIndex//​
-    * Type:​EntryIndex
-  * //dp//
-  * //​metadata//​
-  * //​requests//​
-    * Type:​RequestFlags
-** {{wiki:​ProtectedMethod.gif|}} SetValue(DependencyProperty,​Boolean) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-  * //value//
-    * Type:​Boolean
-** {{wiki:​ProtectedMethod.gif|}} SetCurrentValue(DependencyProperty,​Boolean) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-  * //value//
-    * Type:​Boolean
-** {{wiki:​ProtectedMethod.gif|}} SetValueInternal(DependencyProperty,​Object) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-  * //value//
-    * Type:Object
-** {{wiki:​ProtectedMethod.gif|}} SetCurrentValueInternal(DependencyProperty,​Object) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-  * //value//
-    * Type:Object
-** {{wiki:​ProtectedMethod.gif|}} SetDeferredValue(DependencyProperty,​DeferredReference) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-  * //​deferredReference//​
-    * Type:​DeferredReference
-** {{wiki:​ProtectedMethod.gif|}} SetCurrentDeferredValue(DependencyProperty,​DeferredReference) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-** {{wiki:​ProtectedMethod.gif|}} SetMutableDefaultValue(DependencyProperty,​Object) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-  * //value//
-    * Type:Object
-** {{wiki:​ProtectedMethod.gif|}} SetValue(DependencyPropertyKey,​Boolean) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-  * //value//
-    * Type:​Boolean
-** {{wiki:​ProtectedMethod.gif|}} ProvideSelfAsInheritanceContext(Object,​DependencyProperty) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //value//
-    * Type:Object
-  * //dp//
-** {{wiki:​ProtectedMethod.gif|}} ProvideSelfAsInheritanceContext(DependencyObject,​DependencyProperty) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //doValue//
-  * //dp//
-** {{wiki:​ProtectedMethod.gif|}} RemoveSelfAsInheritanceContext(Object,​DependencyProperty) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //value//
-    * Type:Object
-  * //dp//
-** {{wiki:​ProtectedMethod.gif|}} RemoveSelfAsInheritanceContext(DependencyObject,​DependencyProperty) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //doValue//
-  * //dp//
-** {{wiki:​ProtectedMethod.gif|}} ContainsValue(DependencyProperty) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //dp//
-** {{wiki:​ProtectedMethod.gif|}} InvalidateSubProperty(DependencyProperty) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-** {{wiki:​ProtectedMethod.gif|}} NotifySubPropertyChange(DependencyProperty) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-** {{wiki:​ProtectedMethod.gif|}} InvalidateProperty(DependencyProperty,​Boolean) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-  * //​preserveCurrentValue//​
-    * Type:​Boolean
-** {{wiki:​ProtectedMethod.gif|}} UpdateEffectiveValue(EntryIndex,​DependencyProperty,​PropertyMetadata,​EffectiveValueEntry,​EffectiveValueEntry&,​Boolean,​Boolean,​OperationType) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​UpdateResult
-== Parameters ==
-  * //dp//
-  * //​metadata//​
-  * //​oldEntry//​
-  * //​newEntry//​
-  * //​coerceWithDeferredReference//​
-    * Type:​Boolean
-  * //​coerceWithCurrentValue//​
-    * Type:​Boolean
-  * //​operationType//​
-    * Type:​OperationType
-** {{wiki:​ProtectedMethod.gif|}} NotifyPropertyChange(DependencyPropertyChangedEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //args//
-** {{wiki:​ProtectedMethod.gif|}} ShouldSerializeProperty(DependencyProperty) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //dp//
-** {{wiki:​ProtectedMethod.gif|}} GetValueSource(DependencyProperty,​PropertyMetadata,​Boolean&​) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​BaseValueSourceInternal
-== Parameters ==
-  * //dp//
-  * //​metadata//​
-  * //​hasModifiers//​
-    * Type:​Boolean&​
-** {{wiki:​ProtectedMethod.gif|}} GetValueSource(DependencyProperty,​PropertyMetadata,​Boolean&,​Boolean&,​Boolean&,​Boolean&,​Boolean&​) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-  * //dp//
-  * //​metadata//​
-    * Type:​Boolean&​
-  * //​isExpression//​
-    * Type:​Boolean&​
-  * //​isAnimated//​
-    * Type:​Boolean&​
-  * //​isCoerced//​
-    * Type:​Boolean&​
-  * //​isCurrent//​
-    * Type:​Boolean&​
-** {{wiki:​ProtectedMethod.gif|}} ReadLocalValueEntry(EntryIndex,​DependencyProperty,​Boolean) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Object
-== Parameters ==
-  * //dp//
-  * //​allowDeferredReferences//​
-    * Type:​Boolean
-** {{wiki:​ProtectedMethod.gif|}} HasAnyExpression() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} HasExpression(EntryIndex,​DependencyProperty) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //dp//
-** {{wiki:​ProtectedMethod.gif|}} OnInheritanceContextChanged(EventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //args//
-    * Type:​EventArgs
-** {{wiki:​ProtectedMethod.gif|}} Debug_AssertNoInheritanceContextListeners() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} BeginPropertyInitialization() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} EndPropertyInitialization() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} SetIsSelfInheritanceParent() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} SynchronizeInheritanceParent(DependencyObject) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //parent//
-** {{wiki:​ProtectedMethod.gif|}} LookupEntry(Int32) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-  * //​targetIndex//​
-    * Type:Int32
-** {{wiki:​ProtectedMethod.gif|}} SetEffectiveValue(EntryIndex,​DependencyProperty,​PropertyMetadata,​EffectiveValueEntry,​EffectiveValueEntry) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-    * Type:​DependencyProperty
-  * //​metadata//​
-  * //​newEntry//​
-  * //​oldEntry//​
-** {{wiki:​ProtectedMethod.gif|}} SetEffectiveValue(EntryIndex,​DependencyProperty,​Int32,​PropertyMetadata,​Object,​BaseValueSourceInternal) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-    * Type:Int32
-  * //​metadata//​
-  * //value//
-    * Type:Object
-  * //​valueSource//​
-** {{wiki:​ProtectedMethod.gif|}} UnsetEffectiveValue(EntryIndex,​DependencyProperty,​PropertyMetadata) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //dp//
-  * //​metadata//​
-** {{wiki:​ProtectedMethod.gif|}} DetachFromDispatcher() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Object
-== Parameters ==
-** {{wiki:​PublicProperty.gif|}} Position **
-This property gets and sets the position of the popup.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Point
-** {{wiki:​PublicProperty.gif|}} ArrowHeight **
-Gets or sets the height of the arrow.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-** {{wiki:​PublicProperty.gif|}} Content **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Object
-** {{wiki:​PublicProperty.gif|}} HasContent **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} ContentTemplate **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​DataTemplate
-** {{wiki:​PublicProperty.gif|}} ContentTemplateSelector **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​DataTemplateSelector
-** {{wiki:​PublicProperty.gif|}} ContentStringFormat **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:String
-** {{wiki:​PublicProperty.gif|}} BorderBrush **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Brush
-** {{wiki:​PublicProperty.gif|}} BorderThickness **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Thickness
-** {{wiki:​PublicProperty.gif|}} Background **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Brush
-** {{wiki:​PublicProperty.gif|}} Foreground **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Brush
-** {{wiki:​PublicProperty.gif|}} FontFamily **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​FontFamily
-** {{wiki:​PublicProperty.gif|}} FontSize **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Double
-** {{wiki:​PublicProperty.gif|}} FontStretch **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​FontStretch
-** {{wiki:​PublicProperty.gif|}} FontStyle **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​FontStyle
-** {{wiki:​PublicProperty.gif|}} FontWeight **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​FontWeight
-** {{wiki:​PublicProperty.gif|}} HorizontalContentAlignment **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​HorizontalAlignment
-** {{wiki:​PublicProperty.gif|}} VerticalContentAlignment **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​VerticalAlignment
-** {{wiki:​PublicProperty.gif|}} TabIndex **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-** {{wiki:​PublicProperty.gif|}} IsTabStop **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} Padding **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Thickness
-** {{wiki:​PublicProperty.gif|}} Template **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​ControlTemplate
-** {{wiki:​PublicProperty.gif|}} Style **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Style
-** {{wiki:​PublicProperty.gif|}} OverridesDefaultStyle **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} UseLayoutRounding **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} Triggers **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​TriggerCollection
-** {{wiki:​PublicProperty.gif|}} TemplatedParent **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​PublicProperty.gif|}} Resources **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​ResourceDictionary
-** {{wiki:​PublicProperty.gif|}} DataContext **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Object
-** {{wiki:​PublicProperty.gif|}} BindingGroup **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​BindingGroup
-** {{wiki:​PublicProperty.gif|}} Language **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​XmlLanguage
-** {{wiki:​PublicProperty.gif|}} Name **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:String
-** {{wiki:​PublicProperty.gif|}} Tag **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Object
-** {{wiki:​PublicProperty.gif|}} InputScope **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​InputScope
-** {{wiki:​PublicProperty.gif|}} ActualWidth **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Double
-** {{wiki:​PublicProperty.gif|}} ActualHeight **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Double
-** {{wiki:​PublicProperty.gif|}} LayoutTransform **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Transform
-** {{wiki:​PublicProperty.gif|}} Width **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Double
-** {{wiki:​PublicProperty.gif|}} MinWidth **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Double
-** {{wiki:​PublicProperty.gif|}} MaxWidth **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Double
-** {{wiki:​PublicProperty.gif|}} Height **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Double
-** {{wiki:​PublicProperty.gif|}} MinHeight **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Double
-** {{wiki:​PublicProperty.gif|}} MaxHeight **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Double
-** {{wiki:​PublicProperty.gif|}} FlowDirection **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​FlowDirection
-** {{wiki:​PublicProperty.gif|}} Margin **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Thickness
-** {{wiki:​PublicProperty.gif|}} HorizontalAlignment **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​PublicProperty.gif|}} VerticalAlignment **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​PublicProperty.gif|}} FocusVisualStyle **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Style
-** {{wiki:​PublicProperty.gif|}} Cursor **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Cursor
-** {{wiki:​PublicProperty.gif|}} ForceCursor **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} IsInitialized **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} IsLoaded **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} ToolTip **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Object
-** {{wiki:​PublicProperty.gif|}} ContextMenu **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​PublicProperty.gif|}} Parent **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​PublicProperty.gif|}} HasAnimatedProperties **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} InputBindings **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​InputBindingCollection
-** {{wiki:​PublicProperty.gif|}} CommandBindings **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​CommandBindingCollection
-** {{wiki:​PublicProperty.gif|}} AllowDrop **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} DesiredSize **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Size
-** {{wiki:​PublicProperty.gif|}} IsMeasureValid **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} IsArrangeValid **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} RenderSize **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Size
-** {{wiki:​PublicProperty.gif|}} RenderTransform **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Transform
-** {{wiki:​PublicProperty.gif|}} RenderTransformOrigin **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Point
-** {{wiki:​PublicProperty.gif|}} IsMouseDirectlyOver **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} IsMouseOver **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} IsStylusOver **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} IsKeyboardFocusWithin **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} IsMouseCaptured **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} IsMouseCaptureWithin **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} IsStylusDirectlyOver **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} IsStylusCaptured **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} IsStylusCaptureWithin **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} IsKeyboardFocused **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} IsInputMethodEnabled **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} Opacity **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Double
-** {{wiki:​PublicProperty.gif|}} OpacityMask **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Brush
-** {{wiki:​PublicProperty.gif|}} BitmapEffect **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​BitmapEffect
-** {{wiki:​PublicProperty.gif|}} Effect **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Effect
-** {{wiki:​PublicProperty.gif|}} BitmapEffectInput **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​BitmapEffectInput
-** {{wiki:​PublicProperty.gif|}} CacheMode **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​CacheMode
-** {{wiki:​PublicProperty.gif|}} Uid **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:String
-** {{wiki:​PublicProperty.gif|}} Visibility **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Visibility
-** {{wiki:​PublicProperty.gif|}} ClipToBounds **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} Clip **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Geometry
-** {{wiki:​PublicProperty.gif|}} SnapsToDevicePixels **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} IsFocused **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} IsEnabled **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} IsHitTestVisible **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} IsVisible **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} Focusable **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} PersistId **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-** {{wiki:​PublicProperty.gif|}} IsManipulationEnabled **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} AreAnyTouchesOver **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} AreAnyTouchesDirectlyOver **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} AreAnyTouchesCapturedWithin **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} AreAnyTouchesCaptured **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} TouchesCaptured **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​IEnumerable<​TouchDevice>​
-** {{wiki:​PublicProperty.gif|}} TouchesCapturedWithin **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​PublicProperty.gif|}} TouchesOver **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​PublicProperty.gif|}} TouchesDirectlyOver **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​PublicProperty.gif|}} DependencyObjectType **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​DependencyObjectType
-** {{wiki:​PublicProperty.gif|}} IsSealed **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} Dispatcher **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Dispatcher
-** {{wiki:​ProtectedProperty.gif|}} LogicalChildren **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​IEnumerator
-** {{wiki:​ProtectedProperty.gif|}} ContentIsNotLogical **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} ContentIsItem **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} EffectiveValuesInitialSize **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-** {{wiki:​ProtectedProperty.gif|}} DTypeThemeStyleKey **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​ProtectedProperty.gif|}} TemplateInternal **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​FrameworkTemplate
-** {{wiki:​ProtectedProperty.gif|}} TemplateCache **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​ProtectedProperty.gif|}} HandlesScrolling **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} VisualStateChangeSuspended **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} DefaultStyleKey **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Object
-** {{wiki:​ProtectedProperty.gif|}} ThemeStyle **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Style
-** {{wiki:​ProtectedProperty.gif|}} IsTemplateRoot **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} TemplateChild **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​UIElement
-** {{wiki:​ProtectedProperty.gif|}} StateGroupsRoot **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​FrameworkElement
-** {{wiki:​ProtectedProperty.gif|}} VisualChildrenCount **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-** {{wiki:​ProtectedProperty.gif|}} HasResources **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} InheritanceBehavior **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​InheritanceBehavior
-** {{wiki:​ProtectedProperty.gif|}} HasResourceReference **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} IsLogicalChildrenIterationInProgress **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} InVisibilityCollapsedTree **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} SubtreeHasLoadedChangeHandler **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} IsLoadedCache **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} IsParentAnFE **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} IsTemplatedParentAnFE **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} HasLogicalChildren **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} IsRightToLeft **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} TemplateChildIndex **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-** {{wiki:​ProtectedProperty.gif|}} IsRequestingExpression **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} BypassLayoutPolicies **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} ThisHasLoadedChangeEventHandler **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} HasFefLoadedChangeHandler **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} InheritanceContext **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​ProtectedProperty.gif|}} IsStyleUpdateInProgress **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} IsThemeStyleUpdateInProgress **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} StoresParentTemplateValues **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} HasNumberSubstitutionChanged **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} HasTemplateGeneratedSubTree **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} HasImplicitStyleFromResources **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} ShouldLookupImplicitStyles **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} IsStyleSetFromGenerator **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} HasStyleChanged **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} HasTemplateChanged **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} HasStyleInvalidated **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} HasStyleEverBeenFetched **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} HasLocalStyle **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} HasThemeStyleEverBeenFetched **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} AncestorChangeInProgress **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} InheritableProperties **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​FrugalObjectList<​DependencyProperty>​
-** {{wiki:​ProtectedProperty.gif|}} LoadedPending **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Object[]
-** {{wiki:​ProtectedProperty.gif|}} UnloadedPending **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Object[]
-** {{wiki:​ProtectedProperty.gif|}} HasMultipleInheritanceContexts **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} PotentiallyHasMentees **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} InputBindingsInternal **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​ProtectedProperty.gif|}} CommandBindingsInternal **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​ProtectedProperty.gif|}} EventHandlersStore **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​EventHandlersStore
-** {{wiki:​ProtectedProperty.gif|}} StylusPlugIns **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​StylusPlugInCollection
-** {{wiki:​ProtectedProperty.gif|}} PreviousConstraint **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Size
-** {{wiki:​ProtectedProperty.gif|}} HasEffectiveKeyboardFocus **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} IsEnabledCore **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} PreviousArrangeRect **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Rect
-** {{wiki:​ProtectedProperty.gif|}} HasAutomationPeer **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} SnapsToDevicePixelsCache **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} ClipToBoundsCache **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} MeasureDirty **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} ArrangeDirty **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} MeasureInProgress **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} ArrangeInProgress **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} NeverMeasured **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} NeverArranged **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} MeasureDuringArrange **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} AreTransformsClean **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} IsVisualChildrenIterationInProgress **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} IsRootElement **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} VisualContentBounds **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Rect
-** {{wiki:​ProtectedProperty.gif|}} VisualDescendantBounds **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Rect
-** {{wiki:​ProtectedProperty.gif|}} InternalVisualChildrenCount **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-** {{wiki:​ProtectedProperty.gif|}} InternalVisual2DOr3DChildrenCount **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-** {{wiki:​ProtectedProperty.gif|}} HasVisualChildren **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} TreeLevel **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:UInt32
-** {{wiki:​ProtectedProperty.gif|}} VisualParent **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​ProtectedProperty.gif|}} InternalVisualParent **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​ProtectedProperty.gif|}} VisualTransform **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Transform
-** {{wiki:​ProtectedProperty.gif|}} VisualEffect **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Effect
-** {{wiki:​ProtectedProperty.gif|}} VisualEffectInternal **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Effect
-** {{wiki:​ProtectedProperty.gif|}} VisualBitmapEffect **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​ProtectedProperty.gif|}} VisualBitmapEffectInput **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​ProtectedProperty.gif|}} BitmapEffectEmulationDisabled **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} VisualBitmapEffectInternal **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​ProtectedProperty.gif|}} VisualBitmapEffectInputInternal **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​ProtectedProperty.gif|}} VisualCacheMode **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​CacheMode
-** {{wiki:​ProtectedProperty.gif|}} VisualScrollableAreaClip **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Nullable<​Rect>​
-** {{wiki:​ProtectedProperty.gif|}} VisualClip **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Geometry
-** {{wiki:​ProtectedProperty.gif|}} VisualOffset **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Vector
-** {{wiki:​ProtectedProperty.gif|}} VisualOpacity **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Double
-** {{wiki:​ProtectedProperty.gif|}} VisualEdgeMode **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​EdgeMode
-** {{wiki:​ProtectedProperty.gif|}} VisualBitmapScalingMode **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​BitmapScalingMode
-** {{wiki:​ProtectedProperty.gif|}} VisualClearTypeHint **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​ClearTypeHint
-** {{wiki:​ProtectedProperty.gif|}} VisualTextRenderingMode **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​TextRenderingMode
-** {{wiki:​ProtectedProperty.gif|}} VisualTextHintingMode **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​TextHintingMode
-** {{wiki:​ProtectedProperty.gif|}} VisualOpacityMask **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Brush
-** {{wiki:​ProtectedProperty.gif|}} VisualXSnappingGuidelines **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​DoubleCollection
-** {{wiki:​ProtectedProperty.gif|}} VisualYSnappingGuidelines **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​ProtectedProperty.gif|}} ClipChangedHandler **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​ProtectedProperty.gif|}} ScrollableAreaClipChangedHandler **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​ProtectedProperty.gif|}} TransformChangedHandler **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​ProtectedProperty.gif|}} EffectChangedHandler **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​ProtectedProperty.gif|}} CacheModeChangedHandler **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​ProtectedProperty.gif|}} GuidelinesChangedHandler **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​ProtectedProperty.gif|}} OpacityMaskChangedHandler **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​ProtectedProperty.gif|}} ContentsChangedHandler **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​ProtectedProperty.gif|}} IsInheritanceContextSealed **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} Freezable_Frozen **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} Freezable_HasMultipleInheritanceContexts **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} Freezable_UsingHandlerList **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} Freezable_UsingContextList **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} Freezable_UsingSingletonHandler **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} Freezable_UsingSingletonContext **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} Animatable_IsResourceInvalidationNecessary **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} IAnimatable_HasAnimatedProperties **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} CanBeInheritanceContext **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} EffectiveValues **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​EffectiveValueEntry[]
-** {{wiki:​ProtectedProperty.gif|}} EffectiveValuesCount **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:UInt32
-** {{wiki:​ProtectedProperty.gif|}} InheritableEffectiveValuesCount **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:UInt32
-** {{wiki:​ProtectedProperty.gif|}} InheritanceParent **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​ProtectedProperty.gif|}} IsSelfInheritanceParent **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicEvent.gif|}} PreviewMouseDoubleClick **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} MouseDoubleClick **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} TargetUpdated **
-N/A
-== Remarks ==
-N/A
-Event Arguments:​DataTransferEventArgs
-** {{wiki:​PublicEvent.gif|}} SourceUpdated **
-N/A
-== Remarks ==
-N/A
-** {{wiki:​PublicEvent.gif|}} DataContextChanged **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} RequestBringIntoView **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} SizeChanged **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} Initialized **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} Loaded **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} Unloaded **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} ToolTipOpening **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} ToolTipClosing **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} ContextMenuOpening **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} ContextMenuClosing **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewMouseDown **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} MouseDown **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewMouseUp **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} MouseUp **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewMouseLeftButtonDown **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} MouseLeftButtonDown **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewMouseLeftButtonUp **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} MouseLeftButtonUp **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewMouseRightButtonDown **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} MouseRightButtonDown **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewMouseRightButtonUp **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} MouseRightButtonUp **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewMouseMove **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} MouseMove **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewMouseWheel **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} MouseWheel **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} MouseEnter **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} MouseLeave **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} GotMouseCapture **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} LostMouseCapture **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} QueryCursor **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewStylusDown **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} StylusDown **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewStylusUp **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} StylusUp **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewStylusMove **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} StylusMove **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewStylusInAirMove **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} StylusInAirMove **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} StylusEnter **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} StylusLeave **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewStylusInRange **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} StylusInRange **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewStylusOutOfRange **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} StylusOutOfRange **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewStylusSystemGesture **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} StylusSystemGesture **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} GotStylusCapture **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} LostStylusCapture **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} StylusButtonDown **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} StylusButtonUp **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewStylusButtonDown **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewStylusButtonUp **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewKeyDown **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} KeyDown **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewKeyUp **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} KeyUp **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewGotKeyboardFocus **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} GotKeyboardFocus **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewLostKeyboardFocus **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} LostKeyboardFocus **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewTextInput **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} TextInput **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewQueryContinueDrag **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} QueryContinueDrag **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewGiveFeedback **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} GiveFeedback **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewDragEnter **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} DragEnter **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewDragOver **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} DragOver **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewDragLeave **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} DragLeave **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewDrop **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} Drop **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} PreviewTouchDown **
-N/A
-== Remarks ==
-N/A
-Event Arguments:​TouchEventArgs
-** {{wiki:​PublicEvent.gif|}} TouchDown **
-N/A
-== Remarks ==
-N/A
-** {{wiki:​PublicEvent.gif|}} PreviewTouchMove **
-N/A
-== Remarks ==
-N/A
-** {{wiki:​PublicEvent.gif|}} TouchMove **
-N/A
-== Remarks ==
-N/A
-** {{wiki:​PublicEvent.gif|}} PreviewTouchUp **
-N/A
-== Remarks ==
-N/A
-** {{wiki:​PublicEvent.gif|}} TouchUp **
-N/A
-== Remarks ==
-N/A
-** {{wiki:​PublicEvent.gif|}} GotTouchCapture **
-N/A
-== Remarks ==
-N/A
-** {{wiki:​PublicEvent.gif|}} LostTouchCapture **
-N/A
-== Remarks ==
-N/A
-** {{wiki:​PublicEvent.gif|}} TouchEnter **
-N/A
-== Remarks ==
-N/A
-** {{wiki:​PublicEvent.gif|}} TouchLeave **
-N/A
-== Remarks ==
-N/A
-** {{wiki:​PublicEvent.gif|}} IsMouseDirectlyOverChanged **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} IsKeyboardFocusWithinChanged **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} IsMouseCapturedChanged **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} IsMouseCaptureWithinChanged **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} IsStylusDirectlyOverChanged **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} IsStylusCapturedChanged **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} IsStylusCaptureWithinChanged **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} IsKeyboardFocusedChanged **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} LayoutUpdated **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} GotFocus **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} LostFocus **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} IsEnabledChanged **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} IsHitTestVisibleChanged **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} IsVisibleChanged **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} FocusableChanged **
-N/A
-== Remarks ==
-N/A
-Event Arguments:
-** {{wiki:​PublicEvent.gif|}} ManipulationStarting **
-N/A
-== Remarks ==
-N/A
-Event Arguments:​ManipulationStartingEventArgs
-** {{wiki:​PublicEvent.gif|}} ManipulationStarted **
-N/A
-== Remarks ==
-N/A
-Event Arguments:​ManipulationStartedEventArgs
-** {{wiki:​PublicEvent.gif|}} ManipulationDelta **
-N/A
-== Remarks ==
-N/A
-Event Arguments:​ManipulationDeltaEventArgs
-** {{wiki:​PublicEvent.gif|}} ManipulationInertiaStarting **
-N/A
-== Remarks ==
-N/A
-Event Arguments:​ManipulationInertiaStartingEventArgs
-** {{wiki:​PublicEvent.gif|}} ManipulationBoundaryFeedback **
-N/A
-== Remarks ==
-N/A
-Event Arguments:​ManipulationBoundaryFeedbackEventArgs
-** {{wiki:​PublicEvent.gif|}} ManipulationCompleted **
-N/A
-== Remarks ==
-N/A
-Event Arguments:​ManipulationCompletedEventArgs
thinkgeo.mapsuite.wpfdesktopedition.popup.1442546112.txt.gz ยท Last modified: 2015/09/18 03:15 by admin
