thinkgeo.mapsuite.wmsserveredition.wmslayerstyle
thinkgeo.mapsuite.wmsserveredition.wmslayerstyle [2015/08/20 03:08]
-====== ThinkGeo.MapSuite.WmsServerEdition.WmsLayerStyle ======
-<!-- Class -->
-This is a structure that maintains the Style informations for the Capabilities XML DTD.
-=== Remarks ===
-*System.Object
-**[[ThinkGeo.MapSuite.WmsServerEdition.WmsLayerStyle]]
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​WmsLayerStyle()|WmsLayerStyle]] ​  ​| ​   |    | This is a constructor of this class. ​  |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​WmsLayerStyle(String)|WmsLayerStyle]] ​  | String ​  ​| ​   | This is a constructor of this class. ​  |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​WmsLayerStyle(String,​ String)|WmsLayerStyle]] ​  | String, String ​  ​| ​   | This is a constructor of this class. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​Name|Name]] ​  | String ​  ​| ​   | Gets or sets the Name element in the Style node of the Capabilities XML.   |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​Title|Title]] ​  | String ​  ​| ​   | Gets or sets the Title element in the Style node of the Capabilities XML.   |
-==== WmsLayerStyle() ====
-This is a constructor of this class.
-=== Overloads ===
-WmsStyle()
-=== Remarks ===
-=== Parameters ===
-==== WmsLayerStyle(String) ====
-=== Overloads ===
-WmsStyle(string)
-=== Remarks ===
-=== Parameters ===
-| name   | String<​!-- System.String --> ​  | A string value that indicates the Name element in the Style node of the Capabilities XML.   |
-==== WmsLayerStyle(String,​ String) ====
-=== Overloads ===
-WmsStyle(string,​string)
-=== Parameters ===
-| title   | String<​!-- System.String --> ​  | A string value that indicates the Title element in the Style node of the Capabilities XML.   |
-===== Public Methods =====
-==== Equals(Object) ====
-=== Return Value ===
-=== Parameters ===
-<!-- System.Object -->
-[[#Public Methods|Go Back]]
-==== GetHashCode() ====
-=== Parameters ===
-==== GetType() ====
-=== Parameters ===
-==== ToString() ====
-=== Parameters ===
-==== Finalize() ====
-=== Parameters ===
-==== MemberwiseClone() ====
-=== Parameters ===
-==== Name ====
-Gets or sets the Name element in the Style node of the Capabilities XML.
-=== Remarks ===
-^ Return Type ^
-| String<​!-- System.String --> ​  |
-<!-- ThinkGeo.MapSuite.WmsServerEdition.WmsLayerStyle -->
-==== Title ====
-Gets or sets the Title element in the Style node of the Capabilities XML.
-=== Remarks ===
-^ Return Type ^
-===== Public Events =====
-__NOTOC__
-[[Category:​WmsServerEdition]]
-[[Category:​ThinkGeo.MapSuite.WmsServerEdition]]
thinkgeo.mapsuite.wmsserveredition.wmslayerstyle.1440040136.txt.gz ยท Last modified: 2015/09/22 08:50 (external edit)
