thinkgeo.mapsuite.webedition.popup [2015/09/22 08:50] admin |
| - | ====== ThinkGeo.MapSuite.WebEdition.Popup ====== | ||
| - | Serves as the base class that defines the methods and properties common to all types of popups. | ||
| - | *System.Object | ||
| - | ***ThinkGeo.MapSuite.WebEdition.Popup** | ||
| - | *[[ThinkGeo.MapSuite.WebEdition.CloudPopup]] | ||
| - | *[[ThinkGeo.MapSuite.WebEdition.CustomPopup]] | ||
| - | ** {{wiki:ProtectedMethod.gif|}} Popup() ** | ||
| - | * //Initialize an instance of the Popup class.// | ||
| - | == Remarks == | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Popup#Popup.28.29// | ||
| - | == Parameters == | ||
| - | ** {{wiki:ProtectedMethod.gif|}} Popup(String) ** | ||
| - | * //Initialize an instance of the Popup class with the identifier specified.// | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Popup#Popup.28String.29// | ||
| - | * //id// | ||
| - | * Type:String | ||
| - | * Description:The identifier by which you can find the popup. | ||
| - | ** {{wiki:ProtectedMethod.gif|}} Popup(String,PointShape) ** | ||
| - | * //Initialize an instance of the Popup class with the identifier and position specified.// | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Popup#Popup.28String.2C_PointShape.29// | ||
| - | * //id// | ||
| - | * //position// | ||
| - | * Type:[[ThinkGeo.MapSuite.Core.PointShape|PointShape]] | ||
| - | * Description:A point shape in world coordinates that indicates the position of the popup. | ||
| - | ** {{wiki:ProtectedMethod.gif|}} Popup(String,PointShape,Int32,Int32) ** | ||
| - | * //Initialize an instance of the Popup class with the identifier, position, width and height specified.// | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Popup#Popup.28String.2C_PointShape.2C_Int32.2C_Int32.29// | ||
| - | * //id// | ||
| - | * //width// | ||
| - | * Type:Int32 | ||
| - | * Description:An int value that indicates the popup's width. | ||
| - | * //height// | ||
| - | * Description:An int value that indicates the popup's height. | ||
| - | ** {{wiki:ProtectedMethod.gif|}} Popup(String,PointShape,Int32,Int32,Boolean) ** | ||
| - | * //Initialize an instance of the CloundPopup class with an Id string, position, popup content, popup size and a boolean value that determines whether to pan the map if necessary to show the full popup.// | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Popup#Popup.28String.2C_PointShape.2C_Int32.2C_Int32.2C_Boolean.29// | ||
| - | * //id// | ||
| - | * //autoPan// | ||
| - | * Type:Boolean | ||
| - | * Description:A boolean value indicating whether to pan the map if necessary to show the full popup. | ||
| - | ** {{wiki:ProtectedMethod.gif|}} Popup(String,PointShape,Int32,Int32,Boolean,Boolean) ** | ||
| - | * //Initialize an instance of the CloundPopup class with an Id string, position, popup's content, popup size, a boolean value for whether to pan the map to show the popup, and a boolean value for whether to have a close button on the popup.// | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Popup#Popup.28String.2C_PointShape.2C_Int32.2C_Int32.2C_Boolean.2C_Boolean.29// | ||
| - | * //id// | ||
| - | * //hasCloseButton// | ||
| - | * Description:A boolean value indicating whether the popup should have a close button. | ||
| - | ** {{wiki:PublicMethod.gif|}} CloneShallow() ** | ||
| - | * //Creates a shallow copy of the current popup object.// | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Popup#CloneShallow.28.29// | ||
| - | == Return Value == | ||
| - | * Type:[[ThinkGeo.MapSuite.WebEdition.Popup|Popup]] | ||
| - | * Description:N/A | ||
| - | ** {{wiki:PublicMethod.gif|}} ToJson() ** | ||
| - | * //Returns a JSON string which contains the popup's information and is used to create the popup at the client side.// | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Popup#ToJson.28.29// | ||
| - | * Description:A string that is used to create the popup at the client side. | ||
| - | * //N/A// | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Popup#ToString.28.29// | ||
| - | * //N/A// | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Popup#Equals.28Object.29// | ||
| - | * //obj// | ||
| - | * Type:Object | ||
| - | * //N/A// | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Popup#GetHashCode.28.29// | ||
| - | * //N/A// | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Popup#GetType.28.29// | ||
| - | * Type:Type | ||
| - | * //N/A// | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Popup#Finalize.28.29// | ||
| - | * Type:Void | ||
| - | * //N/A// | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Popup#MemberwiseClone.28.29// | ||
| - | ** {{wiki:PublicProperty.gif|}} Id ** | ||
| - | Gets the identifier by which you can find the popup. | ||
| - | For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Popup#Id | ||
| - | ** {{wiki:PublicProperty.gif|}} Position ** | ||
| - | Gets or sets a point shape in world coordinates that represents the position of the popup. | ||
| - | For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Popup#Position | ||
| - | ** {{wiki:PublicProperty.gif|}} Width ** | ||
| - | Gets or sets the width of the popup. | ||
| - | For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Popup#Width | ||
| - | ** {{wiki:PublicProperty.gif|}} Height ** | ||
| - | Gets or sets the height of the popup. | ||
| - | For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Popup#Height | ||
| - | ** {{wiki:PublicProperty.gif|}} IsVisible ** | ||
| - | Gets or sets a value that indicates whether the popup is visible on the map. | ||
| - | For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Popup#IsVisible | ||
| - | ** {{wiki:PublicProperty.gif|}} Opacity ** | ||
| - | Gets or sets the opacity level of the popup. | ||
| - | The <strong>Opacity</strong> property enables you to specify a level of transparency for the popup. When this property is set to a value less than 100 percent (1.00), the entire popup (including its content) is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the popup completely invisible. | ||
| - | * Type:Single | ||
| - | ** {{wiki:PublicProperty.gif|}} AutoSize ** | ||
| - | Gets or sets a value that indicates whether the popup is automatically resized to fit its contents. | ||
| - | For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Popup#AutoSize | ||
| - | ** {{wiki:PublicProperty.gif|}} AutoPan ** | ||
| - | Gets or sets a value that indicates whether to pan the map to display the entire popup if the popup is not fully displayed. | ||
| - | For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Popup#AutoPan | ||
| - | ** {{wiki:PublicProperty.gif|}} HasCloseButton ** | ||
| - | Gets or sets a value that indicates whether the popup window has a close button in the upper right corner. | ||
| - | For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Popup#HasCloseButton | ||
| - | ** {{wiki:PublicProperty.gif|}} OffsetXInPixels ** | ||
| - | Gets or sets the popup's pixel offset in X direction. | ||
| - | For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Popup#OffsetXInPixels | ||
| - | ** {{wiki:PublicProperty.gif|}} OffsetYInPixels ** | ||
| - | Gets or sets the popup's pixel offset in Y direction. | ||
| - | For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Popup#OffsetYInPixels | ||
| - | ** {{wiki:ProtectedProperty.gif|}} PopupType ** | ||
| - | Gets a string that represents the type of the Popup object. | ||
| - | For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.Popup#PopupType | ||
