thinkgeo.mapsuite.webedition.popup
thinkgeo.mapsuite.webedition.popup [2015/09/18 03:09]
-====== ThinkGeo.MapSuite.WebEdition.Popup ======
-Serves as the base class that defines the methods and properties common to all types of popups.
-  *System.Object
-    ***ThinkGeo.MapSuite.WebEdition.Popup**
-      *[[ThinkGeo.MapSuite.WebEdition.CloudPopup]]
-      *[[ThinkGeo.MapSuite.WebEdition.CustomPopup]]
-** {{wiki:​ProtectedMethod.gif|}} Popup() **
-Initialize an instance of the Popup class.
-== Remarks ==
-N/A
-== Parameters ==
-<div newline></​div>​
-** {{wiki:​ProtectedMethod.gif|}} Popup(String) **
-Initialize an instance of the Popup class with the identifier specified.
-== Remarks ==
-N/A
-== Parameters ==
-  * //id//
-    * Type:String
-    * Description:​The identifier by which you can find the popup.
-** {{wiki:​ProtectedMethod.gif|}} Popup(String,​PointShape) **
-Initialize an instance of the Popup class with the identifier and position specified.
-== Remarks ==
-N/A
-== Parameters ==
-  * //id//
-    * Type:String
-  * //​position//​
-    * Type:​[[ThinkGeo.MapSuite.Core.PointShape|PointShape]]
-    * Description:​A point shape in world coordinates that indicates the position of the popup.
-** {{wiki:​ProtectedMethod.gif|}} Popup(String,​PointShape,​Int32,​Int32) **
-Initialize an instance of the Popup class with the identifier, position, width and height specified.
-== Remarks ==
-N/A
-== Parameters ==
-  * //id//
-    * Type:String
-  * //​position//​
-  * //width//
-    * Type:Int32
-    * Description:​An int value that indicates the popup'​s width.
-  * //height//
-    * Type:Int32
-    * Description:​An int value that indicates the popup'​s height.
-** {{wiki:​ProtectedMethod.gif|}} Popup(String,​PointShape,​Int32,​Int32,​Boolean) **
-Initialize an instance of the CloundPopup class with an Id string, position, popup content, popup size and a boolean value that determines whether to pan the map if necessary to show the full popup.
-== Remarks ==
-N/A
-== Parameters ==
-  * //id//
-    * Type:String
-  * //​position//​
-  * //width//
-    * Type:Int32
-  * //height//
-    * Type:Int32
-  * //autoPan//
-    * Type:​Boolean
-    * Description:​A boolean value indicating whether to pan the map if necessary to show the full popup.
-** {{wiki:​ProtectedMethod.gif|}} Popup(String,​PointShape,​Int32,​Int32,​Boolean,​Boolean) **
-Initialize an instance of the CloundPopup class with an Id string, position, popup'​s content, popup size, a boolean value for whether to pan the map to show the popup, and a boolean value for whether to have a close button on the popup.
-== Remarks ==
-N/A
-== Parameters ==
-  * //id//
-    * Type:String
-  * //​position//​
-  * //width//
-    * Type:Int32
-  * //height//
-    * Type:Int32
-  * //autoPan//
-    * Type:​Boolean
-  * //​hasCloseButton//​
-    * Type:​Boolean
-    * Description:​A boolean value indicating whether the popup should have a close button.
-** {{wiki:​PublicMethod.gif|}} CloneShallow() **
-Creates a shallow copy of the current popup object.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​[[ThinkGeo.MapSuite.WebEdition.Popup|Popup]]
-  * Description:​N/​A
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} ToJson() **
-Returns a JSON string which contains the popup'​s information and is used to create the popup at the client side.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:String
-  * Description:​A string that is used to create the popup at the client side.
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:String
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //obj//
-    * Type:Object
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Type
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Object
-== Parameters ==
-** {{wiki:​PublicProperty.gif|}} Id **
-Gets the identifier by which you can find the popup.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:String
-** {{wiki:​PublicProperty.gif|}} Position **
-Gets or sets a point shape in world coordinates that represents the position of the popup.
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​PublicProperty.gif|}} Width **
-Gets or sets the width of the popup.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-** {{wiki:​PublicProperty.gif|}} Height **
-Gets or sets the height of the popup.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-** {{wiki:​PublicProperty.gif|}} IsVisible **
-Gets or sets a value that indicates whether the popup is visible on the map.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} Opacity **
-Gets or sets the opacity level of the popup.
-== Remarks ==
-The Opacity property enables you to specify a level of transparency for the popup. When this property is set to a value less than 100 percent (1.00), the entire popup (including its content) is made more transparent. The lower the value, the more transparent it is.  Setting this property to a value of 0 percent (0.00) makes the popup completely invisible.
-== Return Value ==
-  * Type:Single
-** {{wiki:​PublicProperty.gif|}} AutoSize **
-Gets or sets a value that indicates whether the popup is automatically resized to fit its contents.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} AutoPan **
-Gets or sets a value that indicates whether to pan the map to display the entire popup if the popup is not fully displayed.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} HasCloseButton **
-Gets or sets a value that indicates whether the popup window has a close button in the upper right corner.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} OffsetXInPixels **
-Gets or sets the popup'​s pixel offset in X direction.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-** {{wiki:​PublicProperty.gif|}} OffsetYInPixels **
-Gets or sets the popup'​s pixel offset in Y direction.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-** {{wiki:​ProtectedProperty.gif|}} PopupType **
-Gets a string that represents the type of the Popup object.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:String
thinkgeo.mapsuite.webedition.popup.1442545756.txt.gz ยท Last modified: 2015/09/18 03:09 by admin
