map_suite_routing_release_change_log_version_7.0.0.0 [2015/09/09 10:45] admin |
| - | ====== Map Suite Routing Release Change Log Version 7.0.0.0 ====== | ||
| - | <html> | ||
| - | <div class="WordSection1"> | ||
| - | <p class="MsoNormal"> | ||
| - | <span style="color: gray;">Namespaces</span> | ||
| - | </p> | ||
| - | <span style="color: gray;">New namespaces: 0</span> | ||
| - | </p> | ||
| - | <br/> | ||
| - | <span style="color: gray;">Types</span> | ||
| - | </p> | ||
| - | <span style="color: gray;">Types added in new namespaces: 0</span> | ||
| - | </p> | ||
| - | <span style="color: gray;">Types added to existing namespaces: 0</span> | ||
| - | </p> | ||
| - | <span style="color: gray;">Total number of types added (in both new and existing namespaces): 0</span> | ||
| - | </p> | ||
| - | <span style="color: gray;">Types removed from existing namespaces: 0</span> | ||
| - | </p> | ||
| - | <br/> | ||
| - | <span style="color: gray;">Members</span> | ||
| - | </p> | ||
| - | <span style="color: gray;">Members added on new types: 0</span> | ||
| - | </p> | ||
| - | <span style="color: gray;">Members added to existing types: 5</span> | ||
| - | </p> | ||
| - | <span style="color: gray;">Members removed from existing types: 0</span> | ||
| - | </p> | ||
| - | <span style="color: gray;">Members removed on removed types: 0</span> | ||
| - | </p> | ||
| - | <br/> | ||
| - | <span style="color: gray;">Attributes</span> | ||
| - | </p> | ||
| - | <span style="color: gray;">Attributes added: 3</span> | ||
| - | </p> | ||
| - | <span style="color: gray;">Attributes added and shown: 3</span> | ||
| - | </p> | ||
| - | <span style="color: gray;">Attributes removed: 0</span> | ||
| - | </p> | ||
| - | <span style="color: gray;">Attributes removed and shown: 0</span> | ||
| - | </p> | ||
| - | <br/> | ||
| - | <span style="color: gray;">Others</span> | ||
| - | </p> | ||
| - | <span style="color: gray;">Parameter name changes: 0</span> | ||
| - | </p> | ||
| - | <br/> | ||
| - | <span style="color: Gray;"><nowiki>//</nowiki> Old assemblies: </span></p> | ||
| - | <span style="color: Gray;"><nowiki>//</nowiki> C:\ThinkGeo\Output\MapSuite3.0\MapSuiteRouting\6.0.0.0\Routing\MapSuiteRouting.dll, Assembly Version=6.0.0.0, File Version=6.0.0.0</span></p> | ||
| - | <span style="color: Gray;"><nowiki>//</nowiki> Total number of old assemblies: 1</span></p> | ||
| - | <br/> | ||
| - | <span style="color: Gray;"><nowiki>//</nowiki> New assemblies: </span></p> | ||
| - | <span style="color: Gray;"><nowiki>//</nowiki> C:\ThinkGeo\Output\MapSuite3.0\MapSuiteRouting\7.0.0.0\Managed Assemblies\MapSuiteRouting.dll, Assembly Version=7.0.0.0, File Version=7.0.0.0</span></p> | ||
| - | <span style="color: Gray;"><nowiki>//</nowiki> Total number of new assemblies: 1</span></p> | ||
| - | <br/> | ||
| - | <span><b>MapSuiteRouting, Version=7.0.0.0, Culture=neutral, PublicKeyToken=null</b></span></p> | ||
| - | <br/> | ||
| - | <span>namespace</span><span><b> ThinkGeo.MapSuite.Routing</b></span><span> {</span></p> | ||
| - | <span> [</span><span>SerializableAttribute</span><span>]</span></p> | ||
| - | <span> public</span><span> class</span><span><b> RoutingEngine</b></span><span> {</span></p> | ||
| - | <span style="color: Green;"> public</span><span style="color: Green;"> PolygonShape</span><span style="color: Green;"><b> GenerateServiceArea</b></span><span style="color: Green;">(</span><span style="color: Green;">PointShape</span><span style="color: Green;"><b> centerPoint</b></span><span style="color: Green;">,</span><span style="color: Green;"> TimeSpan</span><span style="color: Green;"><b> drivingTime</b></span><span style="color: Green;">)</span><span style="color: Green;">;</span></p> | ||
| - | <span style="color: Green;"> public</span><span style="color: Green;"> PolygonShape</span><span style="color: Green;"><b> GenerateServiceArea</b></span><span style="color: Green;">(</span><span style="color: Green;">String</span><span style="color: Green;"><b> centerFeatureId</b></span><span style="color: Green;">,</span><span style="color: Green;"> TimeSpan</span><span style="color: Green;"><b> drivingTime</b></span><span style="color: Green;">)</span><span style="color: Green;">;</span></p> | ||
| - | <br/> | ||
| - | <span style="color: Green;"> protected</span><span style="color: Green;"> virtual</span><span style="color: Green;"> RoutingResult</span><span style="color: Green;"><b> GetRouteCoreWithPoints</b></span><span style="color: Green;">(</span><span style="color: Green;">PointShape</span><span style="color: Green;"><b> startPoint</b></span><span style="color: Green;">,</span><span style="color: Green;"> PointShape</span><span style="color: Green;"><b> endPoint</b></span><span style="color: Green;">,</span><span style="color: Green;"> IEnumerable<PointShape></span><span style="color: Green;"><b> stops</b></span><span style="color: Green;">,</span><span style="color: Green;"> Int32</span><span style="color: Green;"><b> iterations</b></span><span style="color: Green;">)</span><span style="color: Green;">;</span></p> | ||
| - | <span> }</span></p> | ||
| - | <br/> | ||
| - | <span> public</span><span> class</span><span><b> RoutingLayer</b></span><span> :</span><span> Layer</span><span> {</span></p> | ||
| - | <span style="color: Green;"> [</span><span|style="color: Green;">ObsoleteAttribute</span><span style="color: Green;">(</span><span style="color: Green;">"This method is obsolete, please use RoutingLayer(PointShape startPoint, PointShape endPoint, IEnumerable<PointShape> stopPoints, IEnumerable<LineShape> routes) instead. This API is obsolete and may be removed in or after Version 8.0."</span><span style="color: Green;">)</span><span style="color: Green;">]</span></p> | ||
| - | <span> public</span><span><b> RoutingLayer</b></span><span>(</span><span>IEnumerable<MultilineShape></span><span><b> routes</b></span><span>)</span><span>;</span></p> | ||
| - | <span style="color: Green;"> public</span><span style="color: Green;"><b> RoutingLayer</b></span><span style="color: Green;">(</span><span style="color: Green;">IEnumerable<LineShape></span><span style="color: Green;"><b> routes</b></span><span style="color: Green;">)</span><span style="color: Green;">;</span></p> | ||
| - | <span> public</span><span><b> RoutingLayer</b></span><span>(</span><span>PointShape</span><span><b> startPoint</b></span><span>,</span><span> PointShape</span><span><b> endPoint</b></span><span>,</span><span> IEnumerable<PointShape></span><span><b> stopPoints</b></span><span>,</span><span> IEnumerable<MultilineShape></span><span><b> routes</b></span><span>)</span><span>;</span></p> | ||
| - | <span style="color: Green;"> public</span><span style="color: Green;"><b> RoutingLayer</b></span><span style="color: Green;">(</span><span style="color: Green;">PointShape</span><span style="color: Green;"><b> startPoint</b></span><span style="color: Green;">,</span><span style="color: Green;"> PointShape</span><span style="color: Green;"><b> endPoint</b></span><span style="color: Green;">,</span><span style="color: Green;"> IEnumerable<PointShape></span><span style="color: Green;"><b> stopPoints</b></span><span style="color: Green;">,</span><span style="color: Green;"> IEnumerable<LineShape></span><span style="color: Green;"><b> routes</b></span><span style="color: Green;">)</span><span style="color: Green;">;</span></p> | ||
| - | <br/> | ||
| - | <span> public</span><span style="color: Green;"> Collection<LineShape></span><span style="color: Red;"> Collection<MultilineShape></span><span><b> Routes</b></span><span> {</span><span> get</span><span>;</span><span> }</span></p> | ||
| - | <br/> | ||
| - | <span> public</span><span> class</span><span><b> RoutingResult</b></span><span> {</span></p> | ||
| - | <span> public</span><span style="color: Green;"> LineShape</span><span style="color: Red;"> MultilineShape</span><span><b> Route</b></span><span> {</span><span> get</span><span>;</span><span> set</span><span>;</span><span> }</span></p> | ||
| - | <br/> | ||
| - | <span style="color: Green;"> [</span><span|style="color: Green;">ObsoleteAttribute</span><span style="color: Green;">(</span><span style="color: Green;">"This method is obsolete, please use Route property instead. This API is obsolete and may be removed in or after Version 8.0."</span><span style="color: Green;">)</span><span style="color: Green;">]</span></p> | ||
| - | <span> public</span><span> LineShape</span><span><b> GetSingleLineRoute</b></span><span>(</span><span>)</span><span>;</span></p> | ||
| - | <span>}</span><span style="color: Gray;"> <nowiki>//</nowiki> end of namespace ThinkGeo.MapSuite.Routing</span></p> | ||
| - | <br/> | ||
| - | </html> | ||
