map_suite_routing_release_change_log_version_6.0.0.0
map_suite_routing_release_change_log_version_6.0.0.0 [2015/08/20 03:08]
-====== Map_Suite_Routing_Release_Change_Log_Version_6.0.0.0 ======
-Release date: 05/​14/​2012 ​
-<div class="​WordSection1">​
-    <p class="​MsoNormal">​
-<span style="​color:​ gray;">​Namespaces</​span>​
-</p>
-<p class="​MsoNormal">​
-<span style="​color:​ gray;">​New namespaces: 0</​span>​
-</p>
-<br/>
-<span style="​color:​ gray;">​Types</​span>​
-</p>
-<span style="​color:​ gray;">​Types added in new namespaces: 0</​span>​
-</p>
-<span style="​color:​ gray;">​Types added to existing namespaces: 0</​span>​
-</p>
-<span style="​color:​ gray;">​Total number of types added (in both new and existing namespaces):​ 0</​span>​
-</p>
-<span style="​color:​ gray;">​Types removed from existing namespaces: 1</​span>​
-</p>
-<br/>
-<span style="​color:​ gray;">​Members</​span>​
-</p>
-<span style="​color:​ gray;">​Members added on new types: 0</​span>​
-</p>
-<span style="​color:​ gray;">​Members added to existing types: 0</​span>​
-</p>
-<span style="​color:​ gray;">​Members removed from existing types: 7</​span>​
-</p>
-<span style="​color:​ gray;">​Members removed on removed types: 2</​span>​
-</p>
-<br/>
-<span style="​color:​ gray;">​Attributes</​span>​
-</p>
-<span style="​color:​ gray;">​Attributes added: 0</​span>​
-</p>
-<span style="​color:​ gray;">​Attributes added and shown: 0</​span>​
-</p>
-<span style="​color:​ gray;">​Attributes removed: 0</​span>​
-</p>
-<span style="​color:​ gray;">​Attributes removed and shown: 0</​span>​
-</p>
-<br/>
-<span style="​color:​ gray;">​Others</​span>​
-</p>
-<span style="​color:​ gray;">​Parameter name changes: 0</​span>​
-</p>
-<br/>
-<span style="​color:​ Gray;"><​nowiki>//</​nowiki>​ Old assemblies: </​span></​p>​
-<span style="​color:​ Gray;"><​nowiki>//</​nowiki>​ C:​\ThinkGeo\Output\MapSuite3.0\MapSuiteRouting\5.5.0.91\Routing\MapSuiteRouting.dll,​ Assembly Version=5.5.0.0,​ File Version=5.5.0.91</​span></​p>​
-<span style="​color:​ Gray;"><​nowiki>//</​nowiki>​ Total number of old assemblies: 1</​span></​p>​
-<br/>
-<span style="​color:​ Gray;"><​nowiki>//</​nowiki>​ New assemblies: </​span></​p>​
-<span style="​color:​ Gray;"><​nowiki>//</​nowiki>​ C:​\ThinkGeo\Output\MapSuite3.0\MapSuiteRouting\6.0.0.0\Routing\MapSuiteRouting.dll,​ Assembly Version=6.0.0.0,​ File Version=6.0.0.0</​span></​p>​
-<span style="​color:​ Gray;"><​nowiki>//</​nowiki>​ Total number of new assemblies: 1</​span></​p>​
-<br/>
-<​span><​b>​MapSuiteRouting,​ Version=6.0.0.0,​ Culture=neutral,​ PublicKeyToken=null</​b></​span></​p>​
-<br/>
-<​span>​namespace</​span><​span><​b>​ ThinkGeo.MapSuite.Routing</​b></​span><​span>​ {</​span></​p>​
-<​span> ​   [[</​span><​span>​SerializableAttribute</​span><​span>​]]</​span></​p>​
-<​span> ​   public</​span><​span>​ class</​span><​span><​b>​ RoutingEngine</​b></​span><​span>​ {</​span></​p>​
-<span style="​color:​ Red;"> ​       [[</​span><​span|style="​color:​ Red;">​ObsoleteAttribute</​span><​span style="​color:​ Red;">​(</​span><​span style="​color:​ Red;">"​This method is obsolete, please use GetRouteCore(string startFeatureId,​ string endFeatureId,​ IEnumerable<​string>​ stopFeatureIds,​ int iterations) instead. This API is obsolete and may be removed on or after May 1st 2012."</​span><​span style="​color:​ Red;">,</​span><​span style="​color:​ Red;">​ false</​span><​span style="​color:​ Red;">​)</​span><​span style="​color:​ Red;">​]]</​span></​p>​
-<span style="​color:​ Red;"> ​       protected</​span><​span style="​color:​ Red;">​ virtual</​span><​span style="​color:​ Red;">​ RoutingResult</​span><​span style="​color:​ Red;"><​b>​ GetRouteCore</​b></​span><​span style="​color:​ Red;">​(</​span><​span style="​color:​ Red;">​String</​span><​span style="​color:​ Red;"><​b>​ startFeatureId</​b></​span><​span style="​color:​ Red;">,</​span><​span style="​color:​ Red;">​ String</​span><​span style="​color:​ Red;"><​b>​ endFeatureId</​b></​span><​span style="​color:​ Red;">​)</​span><​span style="​color:​ Red;">;</​span></​p>​
-<span style="​color:​ Red;"> ​       [[</​span><​span|style="​color:​ Red;">​ObsoleteAttribute</​span><​span style="​color:​ Red;">​(</​span><​span style="​color:​ Red;">"​This method is obsolete, please use GetRoute(PointShape startPoint, IEnumerable<​PointShape>​ stops) instead. This API is obsolete and may be removed on or after May 1st 2012."</​span><​span style="​color:​ Red;">,</​span><​span style="​color:​ Red;">​ false</​span><​span style="​color:​ Red;">​)</​span><​span style="​color:​ Red;">​]]</​span></​p>​
-<span style="​color:​ Red;"> ​       public</​span><​span style="​color:​ Red;">​ TspRoutingResult</​span><​span style="​color:​ Red;"><​b>​ GetRouteViaVisitStops</​b></​span><​span style="​color:​ Red;">​(</​span><​span style="​color:​ Red;">​PointShape</​span><​span style="​color:​ Red;"><​b>​ startPoint</​b></​span><​span style="​color:​ Red;">,</​span><​span style="​color:​ Red;">​ IEnumerable<​PointShape></​span><​span style="​color:​ Red;"><​b>​ visitStops</​b></​span><​span style="​color:​ Red;">​)</​span><​span style="​color:​ Red;">;</​span></​p>​
-<span style="​color:​ Red;"> ​       [[</​span><​span|style="​color:​ Red;">​ObsoleteAttribute</​span><​span style="​color:​ Red;">​(</​span><​span style="​color:​ Red;">"​This method is obsolete, please use GetRoute(PointShape startPoint, IEnumerable<​PointShape>​ stops, int iterations) instead. This API is obsolete and may be removed on or after May 1st 2012."</​span><​span style="​color:​ Red;">,</​span><​span style="​color:​ Red;">​ false</​span><​span style="​color:​ Red;">​)</​span><​span style="​color:​ Red;">​]]</​span></​p>​
-<span style="​color:​ Red;"> ​       public</​span><​span style="​color:​ Red;">​ TspRoutingResult</​span><​span style="​color:​ Red;"><​b>​ GetRouteViaVisitStops</​b></​span><​span style="​color:​ Red;">​(</​span><​span style="​color:​ Red;">​PointShape</​span><​span style="​color:​ Red;"><​b>​ startPoint</​b></​span><​span style="​color:​ Red;">,</​span><​span style="​color:​ Red;">​ IEnumerable<​PointShape></​span><​span style="​color:​ Red;"><​b>​ visitStops</​b></​span><​span style="​color:​ Red;">,</​span><​span style="​color:​ Red;">​ Int32</​span><​span style="​color:​ Red;"><​b>​ iterations</​b></​span><​span style="​color:​ Red;">​)</​span><​span style="​color:​ Red;">;</​span></​p>​
-<span style="​color:​ Red;"> ​       [[</​span><​span|style="​color:​ Red;">​ObsoleteAttribute</​span><​span style="​color:​ Red;">​(</​span><​span style="​color:​ Red;">"​This method is obsolete, please use GetRoute(PointShape startPoint, PointShape endPoint, IEnumerable<​PointShape>​ stops, int iterations) instead. This API is obsolete and may be removed on or after May 1st 2012."</​span><​span style="​color:​ Red;">,</​span><​span style="​color:​ Red;">​ false</​span><​span style="​color:​ Red;">​)</​span><​span style="​color:​ Red;">​]]</​span></​p>​
-<span style="​color:​ Red;"> ​       public</​span><​span style="​color:​ Red;">​ TspRoutingResult</​span><​span style="​color:​ Red;"><​b>​ GetRouteViaVisitStops</​b></​span><​span style="​color:​ Red;">​(</​span><​span style="​color:​ Red;">​PointShape</​span><​span style="​color:​ Red;"><​b>​ startPoint</​b></​span><​span style="​color:​ Red;">,</​span><​span style="​color:​ Red;">​ PointShape</​span><​span style="​color:​ Red;"><​b>​ endPoint</​b></​span><​span style="​color:​ Red;">,</​span><​span style="​color:​ Red;">​ IEnumerable<​PointShape></​span><​span style="​color:​ Red;"><​b>​ visitStops</​b></​span><​span style="​color:​ Red;">,</​span><​span style="​color:​ Red;">​ Int32</​span><​span style="​color:​ Red;"><​b>​ iterations</​b></​span><​span style="​color:​ Red;">​)</​span><​span style="​color:​ Red;">;</​span></​p>​
-<span style="​color:​ Red;"> ​       [[</​span><​span|style="​color:​ Red;">​ObsoleteAttribute</​span><​span style="​color:​ Red;">​(</​span><​span style="​color:​ Red;">"​This method is obsolete, please use GetRoute(string startFeatureId,​ string endFeatureId,​ IEnumerable<​string>​ stopFeatureIds,​ int iterations) instead. This API is obsolete and may be removed on or after May 1st 2012."</​span><​span style="​color:​ Red;">,</​span><​span style="​color:​ Red;">​ false</​span><​span style="​color:​ Red;">​)</​span><​span style="​color:​ Red;">​]]</​span></​p>​
-<span style="​color:​ Red;"> ​       public</​span><​span style="​color:​ Red;">​ TspRoutingResult</​span><​span style="​color:​ Red;"><​b>​ GetRouteViaVisitStops</​b></​span><​span style="​color:​ Red;">​(</​span><​span style="​color:​ Red;">​String</​span><​span style="​color:​ Red;"><​b>​ startFeatureId</​b></​span><​span style="​color:​ Red;">,</​span><​span style="​color:​ Red;">​ String</​span><​span style="​color:​ Red;"><​b>​ endFeatureId</​b></​span><​span style="​color:​ Red;">,</​span><​span style="​color:​ Red;">​ IEnumerable<​String></​span><​span style="​color:​ Red;"><​b>​ visitStopFeatureIds</​b></​span><​span style="​color:​ Red;">,</​span><​span style="​color:​ Red;">​ Int32</​span><​span style="​color:​ Red;"><​b>​ iterations</​b></​span><​span style="​color:​ Red;">​)</​span><​span style="​color:​ Red;">;</​span></​p>​
-<span style="​color:​ Red;"> ​       protected</​span><​span style="​color:​ Red;">​ virtual</​span><​span style="​color:​ Red;">​ TspRoutingResult</​span><​span style="​color:​ Red;"><​b>​ GetRouteViaVisitStopsCore</​b></​span><​span style="​color:​ Red;">​(</​span><​span style="​color:​ Red;">​PointShape</​span><​span style="​color:​ Red;"><​b>​ startPoint</​b></​span><​span style="​color:​ Red;">,</​span><​span style="​color:​ Red;">​ IEnumerable<​PointShape></​span><​span style="​color:​ Red;"><​b>​ visitStops</​b></​span><​span style="​color:​ Red;">,</​span><​span style="​color:​ Red;">​ Int32</​span><​span style="​color:​ Red;"><​b>​ iterations</​b></​span><​span style="​color:​ Red;">​)</​span><​span style="​color:​ Red;">;</​span></​p>​
-<​span> ​   }</​span></​p>​
-<br/>
-<​span> ​   public</​span><​span>​ class</​span><​span><​b>​ RoutingLayer</​b></​span><​span>​ :</​span><​span>​ Layer</​span><​span>​ {</​span></​p>​
-<span style="​color:​ Gray;"> ​       protected</​span><​span style="​color:​ Green;">​ override</​span><​span style="​color:​ Red;">​ virtual</​span><​span style="​color:​ Gray;">​ void</​span><​span style="​color:​ Gray;"><​b>​ DrawCore</​b></​span><​span style="​color:​ Gray;">​(</​span><​span style="​color:​ Gray;">​GeoCanvas</​span><​span style="​color:​ Gray;"><​b>​ canvas</​b></​span><​span style="​color:​ Gray;">,</​span><​span style="​color:​ Gray;">​ Collection<​SimpleCandidate></​span><​span style="​color:​ Gray;"><​b>​ labelsInAllLayers</​b></​span><​span style="​color:​ Gray;">​)</​span><​span style="​color:​ Gray;">;</​span></​p>​
-<br/>
-<​span> ​   public</​span><​span>​ class</​span><​span><​b>​ RoutingResult</​b></​span><​span>​ {</​span></​p>​
-<span style="​color:​ Red;"> ​       [[</​span><​span|style="​color:​ Red;">​ObsoleteAttribute</​span><​span style="​color:​ Red;">​(</​span><​span style="​color:​ Red;">"​This property is obsolete, please use method GetSingleLineRoute() instead. This API is obsolete and may be removed on or after May 1st 2012."</​span><​span style="​color:​ Red;">,</​span><​span style="​color:​ Red;">​ false</​span><​span style="​color:​ Red;">​)</​span><​span style="​color:​ Red;">​]]</​span></​p>​
-<span style="​color:​ Red;"> ​       public</​span><​span style="​color:​ Red;">​ LineShape</​span><​span style="​color:​ Red;"><​b>​ SingleLineRoute</​b></​span><​span style="​color:​ Red;">​ {</​span><​span style="​color:​ Red;">​ get</​span><​span style="​color:​ Red;">;</​span><​span style="​color:​ Red;">​ set</​span><​span style="​color:​ Red;">;</​span><​span style="​color:​ Red;">​ }</​span></​p>​
-<br/>
-<span style="​color:​ Red;"> ​   public</​span><​span style="​color:​ Red;">​ class</​span><​span style="​color:​ Red;"><​b>​ TspRoutingResult</​b></​span><​span style="​color:​ Red;">;</​span><​span style="​color:​ Gray;">​ <​nowiki>//</​nowiki>​ removed</​span></​p>​
-<​span>​}</​span><​span style="​color:​ Gray;">​ <​nowiki>//</​nowiki>​ end of namespace ThinkGeo.MapSuite.Routing</​span></​p>​
-<br/>
map_suite_routing_release_change_log_version_6.0.0.0.1440040123.txt.gz ยท Last modified: 2015/09/09 09:09 (external edit)
